Hi all :)
Me 1st post in ages.
What it is i was driving home today ,when i was up shifting through the gears it got stuck on 3rd on would not go into 4th.
So i pulled over and manually forced it into 4th and everything was ok from then on in.
Now I'm thinking i need an engine oil change?
I have an aprilia rs 2001 125cc bike and got told that the pertol oil (2 stroke) is all i need for my bike?
Is this true or do i need separate engine oil for the gears etc....?
Yes if they are a 2 stroke engine that is correct. Check you are using the recommended fuel:oil ratio and that you use a quality oil.
2 stroke engines do not have a seperate oil chamber as they are designed for excellent power : weight performance by virtue of less engine components-- they wear out much quicker than 4 stroke engines -- in fact they use something around a gallon of oil per 1000 miles and are very likely to be banned in future---especially those on outboards
there is some 2 stroke bikes that do use separate oil for the gearbox
not sure which though :?
Hi,
I think the RS125 does have a different oil for the gearbox.
Have you got the owners handbook? It'll tell you if there's a different oil required.
Is there a filler cap on the gearbox?
Personally I thought all 2 strokes used 4 stroke oil in the gearbox. Chris, I'll check the manual when I get home tonight.
http://shop.wemoto.com/pictures.dyn?u=5834144qqq5828515
so it appears there is a need for gearbox oil. Check where filler is and check the level--- do not overfill it.
As said also use a full synthetic 2 stroke oil and allow time for engine to warm up -5 minutes.
So next question is Ginge have you got a manual for this ??---if not please get one
  • 2 weeks later...
