Pete 1963 Posted January 13, 2019 Share Posted January 13, 2019 Hi all, New on here, I found this forum looking for help with a little KH125 I am trying to fix up for the missses to pass her test on. i have been on with this little thing for quite a while and I still cannot seem to get a spark at the plug from it.As far as I am aware, the battery is only needed for the lights etc, & the motor runs straight from the magneto.I have tried,New plug/points/condenser/ignition coilAt one point I found that there was no charge coming from the source coil so I did a home rewind with some wire a guy from a winding place gave me, the correct size (nice helpful bloke actually) but although I did start to get some output, still no spark.I then found a whole new used stator plate complete with points & everything on Ebay which I hoped would do the trick, still no luck.The only thing I've not tried is buying a battery which I am now considering.Short of chucking the whole thing into the Tyne I'm just about at my whits end here so any help gratefully appreciated.Thanks in advance Pete Quote Link to comment Share on other sites More sharing options...
