jw5876 Posted January 21, 2019 Share Posted January 21, 2019 So, on the way home I noticed that my speedometer wasn't illuminated, my spot lights weren't working, my heated grips weren't working and back light was out. Front light is fine as are my brake lights. Could this simply be a blown fuse or something more sinister? Quote Link to comment Share on other sites More sharing options...
Tango Posted January 21, 2019 Share Posted January 21, 2019 Have a look at a wiring diagram and see which fuse feeds the rear light and clocks...... Quote Link to comment Share on other sites More sharing options...
iangaryprice Posted January 21, 2019 Share Posted January 21, 2019 If your spot lights and Heated grips are on the same fuse as the lights, you are probably overloading the circuit. If you do find it is a single fuse, then consider getting the Heated grips at least onto a seperate curcuit. Quote Link to comment Share on other sites More sharing options...
Stu Posted January 21, 2019 Share Posted January 21, 2019 And if it is a blown fuse you need to find the reason as to why it has blown Quote Link to comment Share on other sites More sharing options...
fastbob Posted January 21, 2019 Share Posted January 21, 2019 What did you see when you examined the fuses in the fuse box ? Quote Link to comment Share on other sites More sharing options...
jw5876 Posted January 21, 2019 Author Share Posted January 21, 2019 I haven't had chance yet. Quote Link to comment Share on other sites More sharing options...
