Guest Posted April 8, 2008 Posted April 8, 2008 Okay, so after buying a big bore kit for my 50cc, ive just started to wonder, ill need a new carburetter wont i? Otherwise there wont be enough petrol going in! LOLJust to check, will the model up from mine, the 125, would that carburetter do the job? Cheers Quote
Guest Posted April 8, 2008 Posted April 8, 2008 You will need to get the carbs re-jetted http://www.harley-performance.com/images/cv_jets.jpgthey sit in carb and have a hole, they come in various sizes and you mayhave to get some with bigger hole Quote
Guest Posted April 9, 2008 Posted April 9, 2008 Ask the supplier of the big bore kit what re-jetting you have to do.They might even supply the jets. Quote
Guest Posted April 9, 2008 Posted April 9, 2008 what exactly do you do when you "re-jet" the carbs?if i got the parts would it be possible to do it at home? Quote
Guest Posted April 9, 2008 Posted April 9, 2008 I know it says 4Strokes but the priciples will be the same.http://www.4strokes.com/tech/howtojet.asp Quote
