Slack Posted September 18, 2019 Share Posted September 18, 2019 Hi all, I'm a newbie to this forum and am hoping you clever folks can assist me.My elyseo constantly overheats, I have tried the usual, thermostat and the senser in the rad both appear to be ok. Could it be an air lock? if so how do I bleed the system? Thanks in anticipation. Quote Link to comment Share on other sites More sharing options...
rennie Posted September 18, 2019 Share Posted September 18, 2019 Hello and welcome is the air blocked from getting to the radiator at all?Does it have a cooling fan? If so is that working correctly? Quote Link to comment Share on other sites More sharing options...
Bender Posted September 18, 2019 Share Posted September 18, 2019 I have no idea about your bike but there are a few things that can cause overheating, is it pushing water out or is temp warning coming on? Exhaust gasses pressurising the system will shove water out, ignition timing and or a lean mixture can also cause problems, does it have lack of power? Quote Link to comment Share on other sites More sharing options...
Slack Posted September 19, 2019 Author Share Posted September 19, 2019 Hello and welcome is the air blocked from getting to the radiator at all?Does it have a cooling fan? If so is that working correctly? Hi air appears to be getting to the rad ok, the fan did not seem to be working so I bypassed the switch and fitted a manual switch but it still over heats. Coolant boils out of expansion chamber. Quote Link to comment Share on other sites More sharing options...
Slack Posted September 19, 2019 Author Share Posted September 19, 2019 I have no idea about your bike but there are a few things that can cause overheating, is it pushing water out or is temp warning coming on? Exhaust gasses pressurising the system will shove water out, ignition timing and or a lean mixture can also cause problems, does it have lack of power? Hi, yes water is pushed out of expansion chamber, no lack of power. Quote Link to comment Share on other sites More sharing options...
Bender Posted September 19, 2019 Share Posted September 19, 2019 Get it tested for combustion gasses in water, no idea on your engine but if it has a leak from the cylinder into water it will spit water out, faulty cap and lots of other things will cause the same. Quote Link to comment Share on other sites More sharing options...
Slack Posted September 19, 2019 Author Share Posted September 19, 2019 Get it tested for combustion gasses in water, no idea on your engine but if it has a leak from the cylinder into water it will spit water out, faulty cap and lots of other things will cause the same. Ok will do, many thanks. Quote Link to comment Share on other sites More sharing options...
