Moterbike engine swap
Kawasakiii
Hi all in need of abit of advice got a 1999 kawasaki er5 engine needs too much work for me
looking to buy a new engine but can only find half decent ones from 2004 onward models only but unsure if itll fit or not.
Any help appreciated
Cheers
Guest Richzx6r
Cheers
Where are you based and what needs doing to the engine?
There may be some people around your area that are able to help you out with it
Cheers
Every ER5 engine will fit every ER5 . See my thread in Old Bikes Projects and Restorations entitled ER5 engine swap . I've actually still got my old engine sitting in my backyard if it's any use to you . One thing to remember when buying ER5 engines is that they cannot be made to change gear when they are not in a moving bike . Anything you want to know about the ER5 , let me know .
Gpz500 engines will fit as well
Kle500 also
The GPZ will fit but you're going to have a hard time fabricating a gear change mechanism . At least I think that's correct but I might be wrong .
Edited by fastbob
Cheers
I'm near norwich mate had coolant problems with engine for ages system keeps overpresserising n pissing put of expansion tank done all the external work but no joy engine has gotten really hot a couple of times so dont wanna risk chucking loads of money at it engine was running fine other than the coolant problem apart from couple of days ago so either warped head or gasket or crack in the block
  • Sign up now
