Heated grips take time before they will switch on.
Throttled
I don't use the heated grips that often, but when I do, as soon as I start the bike I switch them (Oxford ones) on, scrolling through the heat settings to the warmest. But today, they refused to switch on and I had to ride off with cold grips. But, after 5 minutes, I tried again and there was some sign of them switching on, as the lowest setting light flickered. After another 5 minutes they worked fine and I was able to switch them on and could feel them warming up my hands.
Is that delay the sign of a pending failure? I am thinking maybe it is a sign the bike battery is on its way out, as I do not ride anything like as much as I used to.
I think if the battery is on the way out, depending on the way they are wired up, the grips would just not turn on or repeatedly turn on/off if the voltage was poor.
How are they wired to the bike? Direct to the battery or via a fused connection? It is quite common for the control units to suffer from water ingress and corrosion to develop on the contacts inside, usually a replacement controller does the trick, or a good clean-up of all the corroded bits and silicone sealant all over the control unit afterwards.
You don't say how old the grips are, if they're not years old it might be worth an email to Oxford complaining, they posted me a new control unit when that happened to me.
There is not much to see with the wiring, the wires go from the control unit into a bundle of other wires that are all inside a sheath that disappears under the tank. I will run it again in the next few days and hope it is some moisture that has now gone.
Now I have heated grips, I cannot imagine not having them.
  • 2 years later...
Mine aren't Oxford, I cheap ones off ebay, With bare hands I can feel heat in about 1-2mins, about 5mins with gloves on. I start with them on max (4) if its not very cold I will end up turning them down after about 15mins.
My Honda OEM ones stopped working and won't be replacing them.
Instead will be getting heated gloves so it doesn't matter which bike I'll be riding and the gloves usually heat quicker with a better heat distribution than grips :thumb:
I tried heated gloves, but they became such a faff connecting/disconnecting them when getting on the bike/off the bike I quickly returned to heated grips.
I have Honda OEM ones on the 600,and they are brilliant. I like how they go into standby mode if the bike is just ticking over, but kick in once reaching 1800rpm,or thereabouts
I have Gerbing heated gloves, which can be used with either batteries or hardwired to the bike. I'm very pleased with them. They don't get hot, you just don't get cold hands. The fingers and back of the hands are kept comfortable.
Heated grips on the FJR where oxford ones and it took a few mins to warm up
People report they get red hot! not in my case 100% was warm but never hot
On the BMW they have 5 settings and don't take long to warm up on setting 3 they are too hot :shock:
id be checking the earth part of the wiring, but if the battery is old it could be that. the bikes running power should boost the amps though to even light up the control so wiring seems the problem. I got my mrs R&G ones which were a very good price and get really hot.
  • Sign up now
