Alspeed67 Posted December 2, 2019 Share Posted December 2, 2019 Just borrowed my mates bike for a couple of months till I get my bike running, Having trouble with High and low beam, stopped working then worked again now its gone off again. checked bulb wire's etc but can't see anything wrong, any advice would be much appreciated. Al. Quote Link to comment Share on other sites More sharing options...
Mississippi Bullfrog Posted December 2, 2019 Share Posted December 2, 2019 Van Van headlights have a habit of vibrating all the time - the good side is that it makes them very visible - the bad side is things shake loose. If both high and low beam are out I'd check the earth. An internal break in the wire is hard to spot, you need to check with a multimeter. Quote Link to comment Share on other sites More sharing options...
