Guest Richzx6r Posted January 9, 2020 Share Posted January 9, 2020 So I have finally managed to replace the left front indicator on my ninja......what a f*cking ball ache that was, so after swapping the wire over from the original to the replacement as the replacement didnt have the connector block on it so once I'd done that I started putting the indicator in to the fairing hole......yea it didnt fit too easily and how I didn't crack the fairing is beyond me and pure blind luck with the amount the fairing was bending.......but after much shouting, swearing and liberal use of lubrication and a screwdriver to Jimmy the bast*rd thing in it's hole.......im left with a couple of small scratches in the well where it sits but nothing too noticeable unless you are really looking for them but bugger me theres got to be an easier way to do it than what I have just experienced........I hope I never have to do another one of them for a bloody long time Quote Link to comment Share on other sites More sharing options...
Mississippi Bullfrog Posted January 9, 2020 Share Posted January 9, 2020 I have eventually learned that there is no such thing as a simple five minutes job.Everything ends up with shouting and swearing. Quote Link to comment Share on other sites More sharing options...
Mickly Posted January 9, 2020 Share Posted January 9, 2020 Too bloody true ...Not bike related but I fixed a leaking tap today, needed to turn off the hot water isolation valve at the boiler, when I turned the valve back on it started leaking from the centre of the valve ( not its connections ) many naughty words were said & much gnashing of teeth and stomping of feet !! Quote Link to comment Share on other sites More sharing options...
Guest Richzx6r Posted January 9, 2020 Share Posted January 9, 2020 I have eventually learned that there is no such thing as a simple five minutes job.Everything ends up with shouting and swearing. It took me nearly two n half hours to get the indicator stalk in to the fairing then 20 minutes to get everything back together........why..just why does it have to be so difficult to change them Quote Link to comment Share on other sites More sharing options...
Guest Richzx6r Posted January 9, 2020 Share Posted January 9, 2020 Too bloody true ...Not bike related but I fixed a leaking tap today, needed to turn off the hot water isolation valve at the boiler, when I turned the valve back on it started leaking from the centre of the valve ( not its connections ) many naughty words were said & much gnashing of teeth and stomping of feet !! And a warm soaking? Quote Link to comment Share on other sites More sharing options...
Mickly Posted January 9, 2020 Share Posted January 9, 2020 Too bloody true ...Not bike related but I fixed a leaking tap today, needed to turn off the hot water isolation valve at the boiler, when I turned the valve back on it started leaking from the centre of the valve ( not its connections ) many naughty words were said & much gnashing of teeth and stomping of feet !! And a warm soaking? No, just a seeping dribble ... Quote Link to comment Share on other sites More sharing options...
Six30 Posted January 9, 2020 Share Posted January 9, 2020 Too bloody true ...Not bike related but I fixed a leaking tap today, needed to turn off the hot water isolation valve at the boiler, when I turned the valve back on it started leaking from the centre of the valve ( not its connections ) many naughty words were said & much gnashing of teeth and stomping of feet !! Twat Quote Link to comment Share on other sites More sharing options...
fastbob Posted January 9, 2020 Share Posted January 9, 2020 Who's Jimmy the bast*rd ? Quote Link to comment Share on other sites More sharing options...
skyrider Posted January 9, 2020 Share Posted January 9, 2020 the joys of working on bikes with fairings Quote Link to comment Share on other sites More sharing options...
fastbob Posted January 9, 2020 Share Posted January 9, 2020 the joys of working on bikes with fairings Which is why after 20 years of f*****g around with plastics I bought a Harley . I could change the plugs without even getting off it . The GSXR would take half a day . Quote Link to comment Share on other sites More sharing options...
Guest Richzx6r Posted January 9, 2020 Share Posted January 9, 2020 Yes its fecking annoying Quote Link to comment Share on other sites More sharing options...
skyrider Posted January 9, 2020 Share Posted January 9, 2020 this is what ups the price of services when you take it to a shop Quote Link to comment Share on other sites More sharing options...
Guest Richzx6r Posted January 9, 2020 Share Posted January 9, 2020 this is what ups the price of services when you take it to a shop Yeah if it was me quoting I'd probably guess at 100 odd quid for it Quote Link to comment Share on other sites More sharing options...
Guest Richzx6r Posted January 9, 2020 Share Posted January 9, 2020 Too bloody true ...Not bike related but I fixed a leaking tap today, needed to turn off the hot water isolation valve at the boiler, when I turned the valve back on it started leaking from the centre of the valve ( not its connections ) many naughty words were said & much gnashing of teeth and stomping of feet !! And a warm soaking? No, just a seeping dribble ... We was talking about the isolation valve not you mickly Quote Link to comment Share on other sites More sharing options...
