Parky Posted June 22, 2020 Posted June 22, 2020 Hi all Hope someone can help out...I have a 1999 xj600s that I’m trying to get up and running Have given the carbs a good clean out , float heights in spec , valve clearances in spec...Put back on the bike and it started straight away so let her warm up , but she sounded a bit lumpy felt the headers and number 1 cylinder is cold only running on 3Pulled the plug it is producing a good strong spark although it did look and feel dry.Any ideas would be much appreciated where to start looking firstFuel , electrical, mechanical!All of the above.. Quote
Bender Posted June 22, 2020 Posted June 22, 2020 If its dry I would look at fuel again for that cylinder Quote
Parky Posted June 22, 2020 Author Posted June 22, 2020 YesCouldn’t remove the drain screw on carb 1 to check, will have to remove carbs again.. Quote
