Guest Posted May 2, 2008 Share Posted May 2, 2008 ok I'll describe what it's like and will someone pleae tell me how to cure it....................in very simple terms....Took one of the kids on the back of the bike, (first time carrying a pillion) when we hit bumps in the road (can't avoid them in sheffield really) it sounded / felt similar to a car bottoming out for a fraction of a second. The bike is a 94 GSX600F, is it me being over cautious, or is it something to do with the suspension.......an if it means me altering it how do i do it?????anymore info needed just ask... Quote Link to comment Share on other sites More sharing options...
Stu Posted May 2, 2008 Share Posted May 2, 2008 how big/little are the kids ?does the suspension go down a lot when they get on ?it could be a case of the rear hugger and undertray are coming into contact take a run outside and look at the tyre, hugger and undertray but it sounds like the preload needs winding up a bit suspension is a black art toouch it and it can go t*ts up or spot on just remember what you have touched and how much so you can go back Quote Link to comment Share on other sites More sharing options...
Guest Posted May 2, 2008 Share Posted May 2, 2008 kid is a young lady of 15, taller than vicki or willow. yes suspension goes down a bit when she gets on.how do i wind the preload up....have got the book and it says 2 threads showing for a single rider 3 or 4 for a passenger, i was assuming that ment at the bottom of the suspension bit.....but there are no threads there at all.... Quote Link to comment Share on other sites More sharing options...
Stu Posted May 2, 2008 Share Posted May 2, 2008 pre load is on the top of the spring check rear hugger like i said first it could just be that Quote Link to comment Share on other sites More sharing options...
Guest Posted May 2, 2008 Share Posted May 2, 2008 brb Quote Link to comment Share on other sites More sharing options...
Guest Posted May 2, 2008 Share Posted May 2, 2008 ok....so steve says there's plenty of room near undertray.but has just told me off saying the chain is far too loose and he thinks it could be that makin the noise by occasionally running on the stand when i've gone over a bump.......... so now i just need to borrow a wrench and sort my chain out...........then try again..... Quote Link to comment Share on other sites More sharing options...
Stu Posted May 2, 2008 Share Posted May 2, 2008 is that plenty of room with both people sat on the bike ? Quote Link to comment Share on other sites More sharing options...
Guest Posted May 6, 2008 Share Posted May 6, 2008 ok the problem is with 2 people on, and goin over a bump the bolt on the swingarm rattles against the exhaust. Quote Link to comment Share on other sites More sharing options...
Guest akey Posted May 7, 2008 Share Posted May 7, 2008 Debs if it only happens when you are 2 up then I would wind the preload up a bit.On the rear shock at one end of the spring there is a couple of rings with slots cut in them, you will need to back one furthest away from the spring off a little (this is the lock ring) then use the one closest the spring to shorten the spring by a couple of turns, then re tighten the lock ring.that should help. Quote Link to comment Share on other sites More sharing options...
Guest Posted May 7, 2008 Share Posted May 7, 2008 Debs if it only happens when you are 2 up then I would wind the preload up a bit.On the rear shock at one end of the spring there is a couple of rings with slots cut in them, you will need to back one furthest away from the spring off a little (this is the lock ring) then use the one closest the spring to shorten the spring by a couple of turns, then re tighten the lock ring.that should help. erm ............... roght......... oookkkkkwhen are you home akey??????? Quote Link to comment Share on other sites More sharing options...
Guest Posted May 7, 2008 Share Posted May 7, 2008 kid is a young lady of 15, taller than vicki or willow.: lets face it so is a http://theretrobaby.com/store/images/umpa-lumpa-heat-transfer.gif Quote Link to comment Share on other sites More sharing options...
