Sue Posted February 2, 2021 Share Posted February 2, 2021 Hello everyone. I have a Honda PCX 125 and it's 4 years old with just 5k miles. No problems at all until today. It starts fine and goes fine but every time I twist throttle more than a little it cuts out as though it has stalled, splutters a bit but then starts again on button ok. Rides no problem at all as long as really gentle with throttle. Any thoughts what this could be? I have notoriously been burned by mechanics before and would be good if I had some idea of what it is before I take it in. Thanks so much for your time in advance. Quote Link to comment Share on other sites More sharing options...
Mississippi Bullfrog Posted February 2, 2021 Share Posted February 2, 2021 Could be a weak spark. Check the ignition system including the spark plug. Has it got damp recently? Quote Link to comment Share on other sites More sharing options...
Bender Posted February 2, 2021 Share Posted February 2, 2021 4 hours ago, Sue said: Hello everyone. I have a Honda PCX 125 and it's 4 years old with just 5k miles. No problems at all until today. It starts fine and goes fine but every time I twist throttle more than a little it cuts out as though it has stalled, splutters a bit but then starts again on button ok. Rides no problem at all as long as really gentle with throttle. Any thoughts what this could be? I have notoriously been burned by mechanics before and would be good if I had some idea of what it is before I take it in. Thanks so much for your time in advance. Roughly where abouts are you, someone may be able to point you in the direction of someone won't rip you off. Quote Link to comment Share on other sites More sharing options...
Sue Posted February 3, 2021 Author Share Posted February 3, 2021 5 hours ago, Mississippi Bullfrog said: Could be a weak spark. Check the ignition system including the spark plug. Has it got damp recently? Yeh it unfortunately sits outside all the time and the weather's been awful. Good advice, thank you Quote Link to comment Share on other sites More sharing options...
Sue Posted February 3, 2021 Author Share Posted February 3, 2021 5 hours ago, Bender said: Roughly where abouts are you, someone may be able to point you in the direction of someone won't rip you off. I'm in Edinburgh. Quote Link to comment Share on other sites More sharing options...
Mississippi Bullfrog Posted February 3, 2021 Share Posted February 3, 2021 I don't know the engine on those but if you can see the lead running to the spark plug give it a spray with WD40. It is a water dispersant so if the lead has got damp into it WD40 might sort it temporarily. When you twist the throttle the air fuel mix is richer to provide more power. That richer mix needs a good spark to ignite it. Engines which bog down on throttle but will pick up on gentle acceleration are often due to the spark being weak. Of course a worn spark plug will do the same. Quote Link to comment Share on other sites More sharing options...
Sue Posted February 3, 2021 Author Share Posted February 3, 2021 12 hours ago, Mississippi Bullfrog said: I don't know the engine on those but if you can see the lead running to the spark plug give it a spray with WD40. It is a water dispersant so if the lead has got damp into it WD40 might sort it temporarily. When you twist the throttle the air fuel mix is richer to provide more power. That richer mix needs a good spark to ignite it. Engines which bog down on throttle but will pick up on gentle acceleration are often due to the spark being weak. Of course a worn spark plug will do the same. Thanks so much that sounds exactly what's happening. I'll try with WWD40 - cheers! Quote Link to comment Share on other sites More sharing options...
RooStu Posted January 21, 2022 Share Posted January 21, 2022 On 03/02/2021 at 19:24, Sue said: Thanks so much that sounds exactly what's happening. I'll try with WWD40 - cheers! Any luck? Mine's doing exactly the same. Need it for work so causing a real problem. Quote Link to comment Share on other sites More sharing options...
