Roadtorque Posted May 18, 2008 Share Posted May 18, 2008 ok I know this should be in the help section,, but thought I might get a quicker response on here,,, Rover 75, had it for 3 years has all ways started first time, till now, starter turns the engine fine but just dead, fuel & pump OK, Spark & plugs OK,,,,, ECU, a Scensor or ????????? any ideas Quote Link to comment Share on other sites More sharing options...
Guest Posted May 18, 2008 Share Posted May 18, 2008 Is the hamster still fit and healthy?http://i202.photobucket.com/albums/aa39/snagglepuss_album/hamster.jpg Quote Link to comment Share on other sites More sharing options...
Guest Posted May 20, 2008 Share Posted May 20, 2008 It's a rover, they're horribly unreliable cars!Does the engine turn over at all? Have you checked the spark plug cables are all securely fastened on top of the plugs. Quote Link to comment Share on other sites More sharing options...
Sk93 Posted May 20, 2008 Share Posted May 20, 2008 When you say the starter turns the engine, does the engine actually fire, but not stay running.. or does it just rotate? Quote Link to comment Share on other sites More sharing options...
Roadtorque Posted May 22, 2008 Author Share Posted May 22, 2008 Thanks guys problem solvedNow running, 2 items in the fuel tank No 1 fuel pump, No2 a thing called an intemsifier that maintains a constant fuel pressure to the engine. so No2 was the problem, now sorted Cheers all thanks for trying RT Quote Link to comment Share on other sites More sharing options...
Guest Posted May 22, 2008 Share Posted May 22, 2008 Thanks guys problem solvedNow running, 2 items in the fuel tank No 1 fuel pump, No2 a thing called an intemsifier that maintains a constant fuel pressure to the engine. so No2 was the problem, now sorted Cheers all thanks for trying RT Get yourself an OBD cable and some software If anything, you save your self the £70 diagnostic fee from the stealer. Quote Link to comment Share on other sites More sharing options...
Guest Posted May 22, 2008 Share Posted May 22, 2008 It's a rover, they're horribly unreliable cars!Does the engine turn over at all? Have you checked the spark plug cables are all securely fastened on top of the plugs. They are?? Feck, better tell my car then. Had it over a year, and got one dead battery.. Original one died, it had only been on there for 110k though, on a 51 plate car. Bit of an over generalisation Bikelegal. Normally a vehicle is only as reliable as the care you give it. Quote Link to comment Share on other sites More sharing options...
