Guest Posted May 31, 2008 Share Posted May 31, 2008 hi can anybody help hubby bought a kymco ck 125 replaced battery but still wont start on the button. kick start fine. it sounds like its trying to start but nothing happens.now the battery wont charge sounds like an earth problem but he doesnt know where to start does anybody have any ideas thanks. oh it never started when he bought it but did yesterday then stopped again today if thats any help Quote Link to comment Share on other sites More sharing options...
Bill_on_a_bike Posted May 31, 2008 Share Posted May 31, 2008 Does it sound like it's turning it over very fast?Could be the starter motors just had it's day and isn't working properly. Quote Link to comment Share on other sites More sharing options...
Guest Posted May 31, 2008 Share Posted May 31, 2008 replace plug--check ht lead is ok--may be carb clean needed--clean air filter--is new battery faulty? if not then alternator prob or regulator or exposed wire shorting--fuel ok and reaching carbs?could be several things Quote Link to comment Share on other sites More sharing options...
Bill_on_a_bike Posted May 31, 2008 Share Posted May 31, 2008 replace plug--check ht lead is ok--may be carb clean needed--clean air filter--is new battery faulty? if not then alternator prob or regulator or exposed wire shorting--fuel ok and reaching carbs?could be several things Surely it kick starting ok eliminates all of these? Quote Link to comment Share on other sites More sharing options...
Guest Posted May 31, 2008 Share Posted May 31, 2008 thought question was about the electric start so had a shot at some checks--it doesn't seem to go with kickstart for long either by sounds of it though Quote Link to comment Share on other sites More sharing options...
Guest Posted June 1, 2008 Share Posted June 1, 2008 with a suzuki you have to pull clutch in and push start, with yams you need to be in nuteral if sidestand down try them Quote Link to comment Share on other sites More sharing options...
