Hoggs Posted August 13, 2021 Share Posted August 13, 2021 Word up you lot. So my new to me bike came with a scottoiler vacuum system. Now it had been sat up for maaaaaany years and was dry so Filled it up Primed it so oil came out Ran engine. Nothing Checked all connectors, elbow joint to engine vacuum cracked! New one purchased and fit. Ran engine. Nothing. Reprimed so oil came out Ran engine. Nothing Now I don't have any clue about this so any help welcome. I did a bit of googling but other than "check vacuum" it's a bit vague thanks in advance! Quote Link to comment Share on other sites More sharing options...
bonio Posted August 13, 2021 Share Posted August 13, 2021 New bike?? Pictures??? Sorry. Old bike had an X System; not a clue about V System. Quote Link to comment Share on other sites More sharing options...
JRH Posted August 13, 2021 Share Posted August 13, 2021 Check that there are no air bubbles in the delivery tube. 1 Quote Link to comment Share on other sites More sharing options...
Hoggs Posted August 13, 2021 Author Share Posted August 13, 2021 (edited) 19 minutes ago, bonio said: New bike?? Pictures??? Sorry. Old bike had an X System; not a clue about V System. Well that's not helpful its the wrong colour I know... but I love it a lot Z750 Edited August 13, 2021 by Hoggs 3 Quote Link to comment Share on other sites More sharing options...
JRH Posted August 13, 2021 Share Posted August 13, 2021 2 minutes ago, Hoggs said: Well that's not helpful its the wrong colour I know... but I love it a lot Z750 Yea, black ones are the quickest. Knew I would convert you sooner or later. . By the way the tax is out of date. 3 Quote Link to comment Share on other sites More sharing options...
Hoggs Posted August 13, 2021 Author Share Posted August 13, 2021 1 minute ago, JRH said: Yea, black ones are the quickest. Knew I would convert you sooner or later. . By the way the tax is out of date. Ha! I took that off shortly after! yeah hadn't been on the road since 2013. Only 13k miles! well...14k now Quote Link to comment Share on other sites More sharing options...
Stu Posted August 13, 2021 Share Posted August 13, 2021 When you say ran engine and nothing how long did you run it for? what setting was the oiler on? Quote Link to comment Share on other sites More sharing options...
Hoggs Posted August 13, 2021 Author Share Posted August 13, 2021 28 minutes ago, Stu said: When you say ran engine and nothing how long did you run it for? what setting was the oiler on? Jesus what is this the Spanish inquisition but probably 2 - 3 mins and around 5? Quote Link to comment Share on other sites More sharing options...
Stu Posted August 13, 2021 Share Posted August 13, 2021 Just now, Hoggs said: Jesus what is this the Spanish inquisition but probably 2 - 3 mins and around 5? No @Bender kicked him out You might need to up the number or run it longer to actually see a drip 1 2 Quote Link to comment Share on other sites More sharing options...
Bender Posted August 13, 2021 Share Posted August 13, 2021 5 minutes ago, Hoggs said: Jesus what is this the Spanish inquisition but probably 2 - 3 mins and around 5? Nobody expects the Spanish inquisition....... 1 Quote Link to comment Share on other sites More sharing options...
bonio Posted August 13, 2021 Share Posted August 13, 2021 Nice bike, Hoggs! And if black is the quickest, then it's the quickest. nuff said 1 Quote Link to comment Share on other sites More sharing options...
Six30 Posted August 14, 2021 Share Posted August 14, 2021 take it off and , bin it and oil it the proper way, Quote Link to comment Share on other sites More sharing options...
Mississippi Bullfrog Posted August 14, 2021 Share Posted August 14, 2021 The oil flow will vary slightly as the vacuum alters, at least that's what I found when I had that system. It makes it very hard to set up right. You need to go for a decent ride to get the oil to drip out. At idle nothing will happen. It's why I didn't buy the same system when I changed bikes. Too hit and miss to set up, and it changes between winter and summer as the oil thickens. Once you find a setting that works leave well alone. 1 Quote Link to comment Share on other sites More sharing options...
oldgrump Posted August 14, 2021 Share Posted August 14, 2021 Hi @Hoggs, Always used scottoilers, easy to set up, Once you primed system, turn the dial back to any number and then start engine, on tickover you should be getting one drip every 60secs, that's what Scottoiler recommend, depending on length of rides it can takes some time fiddling about at first, but well worth it in the end, this year not adjusted chain yet, and we have done a few miles!! Just remember once set only alter small increments, for long wet rides There is also information on Scottoilers website, on set up. 1 Quote Link to comment Share on other sites More sharing options...
Hoggs Posted August 14, 2021 Author Share Posted August 14, 2021 3 minutes ago, oldgrump said: Hi @Hoggs, Always used scottoilers, easy to set up, Once you primed system, turn the dial back to any number and then start engine, on tickover you should be getting one drip every 60secs, that's what Scottoiler recommend, depending on length of rides it can takes some time fiddling about at first, but well worth it in the end, this year not adjusted chain yet, and we have done a few miles!! Just remember once set only alter small increments, for long wet rides There is also information on Scottoilers website, on set up. yeah I just wonder if because it was sat for so long it's gunked up somewhere. Had a little ride out this morning and some MotoGP now so will refiddle later. Nothing ever seems to be easy when I'm involved Quote Link to comment Share on other sites More sharing options...
Bianco2564 Posted August 14, 2021 Share Posted August 14, 2021 7 hours ago, Mississippi Bullfrog said: The oil flow will vary slightly as the vacuum alters, at least that's what I found when I had that system. It makes it very hard to set up right. You need to go for a decent ride to get the oil to drip out. At idle nothing will happen. The first bit is correct, manifold vacuum varies with throttle opening. The second bit is not, at idle there is a strong vacuum as is when cruising on a light throttle. Highest vacuum is on overrun. At full throttle there is no vacuum. If you have ever had a vacuum gauge on a car you would see it go down to zero when you floor it, be somewhere around 18-22in Hg when idling if the engine is healthy. Some genius car manufacturers back in the day used to power the window wipers with manifold vacuum, great until you come to a hill and put your foot down, the wipers stopped. On Hoggs problem, I'd check the vacuum from the engine with a gauge, if all ok it must be the scottoiler unit,got to be a diaphragm of some sort in there, either gummed up or perished. As you say a bit of a faff to set up, I've got one on the R1 and that took a while to find the best setting. 1 Quote Link to comment Share on other sites More sharing options...
Mississippi Bullfrog Posted August 14, 2021 Share Posted August 14, 2021 4 hours ago, Bianco2564 said: The first bit is correct, manifold vacuum varies with throttle opening. The second bit is not, at idle there is a strong vacuum as is when cruising on a light throttle. Highest vacuum is on overrun. At full throttle there is no vacuum. If you have ever had a vacuum gauge on a car you would see it go down to zero when you floor it, be somewhere around 18-22in Hg when idling if the engine is healthy. Some genius car manufacturers back in the day used to power the window wipers with manifold vacuum, great until you come to a hill and put your foot down, the wipers stopped. On Hoggs problem, I'd check the vacuum from the engine with a gauge, if all ok it must be the scottoiler unit,got to be a diaphragm of some sort in there, either gummed up or perished. As you say a bit of a faff to set up, I've got one on the R1 and that took a while to find the best setting. Mine never worked on idle. If I set it to drip on idle then it would pour out oil once on the move. I assumed there is some kind of valve that tries to compensate for variable vacuum that shuts off at full vacuum to prevent oilflow when stationary. You really only want it flowing whilst the chain is turning. Quote Link to comment Share on other sites More sharing options...
Marino Posted August 14, 2021 Share Posted August 14, 2021 On 13/08/2021 at 21:03, Hoggs said: Well that's not helpful its the wrong colour I know... but I love it a lot Z750 Nice bike, I had Z750R mat black many years ago. Great machine 1 Quote Link to comment Share on other sites More sharing options...
onesea Posted August 15, 2021 Share Posted August 15, 2021 My take having had a scotoiler don’t know which system. Mine had vent hose occasionally I would need to give a quick blow suck on it to free the mechanism. Secondly put it on price and see if you can get constant oil flow. Thridly I switched to Lubeman and Gidiaiia on my bikes, Why? Cheaper both have there faults but work well, with both I choose how much oil goes on and when. Scotoilers cannot tell if it’s winter wet ride or dry summer ride… it does make a difference. Yes with all these systems my chains get spray of chain oil from time to time, however having gone through chains with and without oilers they do last longer. However Scotoiler prices make the justification difficult. Quote Link to comment Share on other sites More sharing options...
Mississippi Bullfrog Posted August 16, 2021 Share Posted August 16, 2021 18 hours ago, onesea said: My take having had a scotoiler don’t know which system. Mine had vent hose occasionally I would need to give a quick blow suck on it to free the mechanism. Secondly put it on price and see if you can get constant oil flow. Thridly I switched to Lubeman and Gidiaiia on my bikes, Why? Cheaper both have there faults but work well, with both I choose how much oil goes on and when. Scotoilers cannot tell if it’s winter wet ride or dry summer ride… it does make a difference. Yes with all these systems my chains get spray of chain oil from time to time, however having gone through chains with and without oilers they do last longer. However Scotoiler prices make the justification difficult. Agreed - I have the Gidibii on my CBF - same as the Cobbra Nemo 2 but way cheaper. I can add oil whenever I want to, however much I want to, just takes a quarter turn of the cap and the job's done. 1 Quote Link to comment Share on other sites More sharing options...
