Philip Posted September 6, 2021 Share Posted September 6, 2021 Hi I have a drz 400s 2000 model can I use E10 fuel Quote Link to comment Share on other sites More sharing options...
bonio Posted September 6, 2021 Share Posted September 6, 2021 Hrrmmmm. Not sure. You're supposed to be able to check here: https://check-vehicle-compatibility-e10-petrol.service.gov.uk but the site seems to be down at the mo. Quote Link to comment Share on other sites More sharing options...
Tiggie Posted September 6, 2021 Share Posted September 6, 2021 It should be ok according to the owners manual https://www.manualslib.com/products/Suzuki-Dr-Z400s-2000-5887573.html 1 Quote Link to comment Share on other sites More sharing options...
Tiggie Posted September 6, 2021 Share Posted September 6, 2021 Super unleaded will be staying E5 so if anyone is ever unsure or worried you can always stick that in instead Quote Link to comment Share on other sites More sharing options...
Fozzie Posted September 7, 2021 Share Posted September 7, 2021 In theory it should be able to, places like America have been using E10 for over a decade. And it's a similar story in many parts of the world. Manufacturers knew it was coming for years, and designed their bikes for 5-10% ethanol blended fuel. As a result most bikes back into the mid-90's should be ok. For the ones that aren't compatible, it's not necessarily the end of the story. Many will run on it fine, the issue lies with the fuel lines being made of a lower grade rubber. The effect this extra 5% has on them is huge, in a matter of weeks the flexible lines will be hard as rock, and it will soon clog the fuel system when they break apart. To be safe, I've been telling those with carbed bikes to check their fuel lines first, and spark plugs. Then run a few tanks of E10 over the next couple of months and then check the condition of the lines/spark plug. If you see a sudden hardening of the line, or signs of excessive lean running, you need to replace the lines and rejet the carb. I really shake my head with E10. I won't go into it, but the amount of carbon it offsets has been made to look huge. 750,000 tonnes a year of CO2 sounds impressive but it's a tiny drop. Far bigger savings could easily have been made elsewhere with less disruption. But as usual, it's easier to leave the little guy out of pocket. 1 Quote Link to comment Share on other sites More sharing options...
Gerontious Posted September 7, 2021 Share Posted September 7, 2021 (edited) E10 doesn’t seem to be a thing in Ireland, not seen it at any fuel stop, big brand or independent. Edited September 7, 2021 by Gerontious Quote Link to comment Share on other sites More sharing options...
