Baimo Posted September 9, 2021 Share Posted September 9, 2021 Hi, new 125 rider here i recently changed the crank case on my baimo renegade, uses the same engine as a Lexmoto vixen, and in trying to start it it won’t work, it had drained all oil for 3 or 4 days before the fix, but was sputtering before the fix due to oil leak. The kick start moves so I don’t think the engine is seized but otherwise I have no clue what the problem is, I’ve changed spark plugs I’ve charged the battery, the oil isn’t over full. Please help I need this bike to get to work Quote Link to comment Share on other sites More sharing options...
Guest Posted September 13, 2021 Share Posted September 13, 2021 Is it just kickstart or does it have an electric start? When you try and start it what happens if anything? Does it sound like it's trying to start or us it just completely dead? Quote Link to comment Share on other sites More sharing options...
Stu Posted September 14, 2021 Share Posted September 14, 2021 Check all connections in the area you have been working on as you could have easily pulled or trapped some wiring Quote Link to comment Share on other sites More sharing options...
TimR Posted September 14, 2021 Share Posted September 14, 2021 So by not starting do you mean The engine is not turning over when you press the starter button . or is it Turning over but not starting . ? something to think of if its turning over but not starting The engines may be the same but is ignition pick up the same or does it need thecorresponding ecu/cdi .. Quote Link to comment Share on other sites More sharing options...
