JDAC Posted September 15, 2021 Share Posted September 15, 2021 Hello, I had to leave my yamaha XJ6 in Portugal approx 9 months ago, due to lockdowns and other long stories. I will be going back to it on Monday. Obviously the battery will be flat and quiet possibly dead? My main concern is the petrol and oil which had been sat in there the whole time. Iv ordered some new oil and a filter and intend to do an oil change. The only issue is ideally I'd drive it to my friends house about 5 miles away, where he has a oil tray etc but I'm worried about the old oil in there running through the engine and seizing it. Any advise on that would be greatly appreciated. 2nd Qu is the petrol that's been sat there... is it going to be bad for the engine to run it? Or should I drain it and some new in? Thanks Quote Link to comment Share on other sites More sharing options...
Gerontious Posted September 16, 2021 Share Posted September 16, 2021 You’re worrying too much. It will be fine. If the engine starts then that’s all you need for The run to your friends which will be great for warming up the oil before you change it. 1 Quote Link to comment Share on other sites More sharing options...
Keeper96 Posted September 19, 2021 Share Posted September 19, 2021 Personally I wouldn’t bother changing the oil unless it’s due anyway, charge the battery, top the tank up with fresh fuel and give it a decent run providing there’s no issues with brakes or suspension after being parked up. but being in a daily warm country I’d imagine it’s all fine Quote Link to comment Share on other sites More sharing options...
TimR Posted September 19, 2021 Share Posted September 19, 2021 If the petrol in tank is E10 it may be worth draining and replenishing with fresh..as it absorbs moisture over a shorter time period . ( unsure whenE10 became available in Portugal ) Quote Link to comment Share on other sites More sharing options...
