kaintxu Posted December 2, 2021 Share Posted December 2, 2021 Hi everyone, My tracer900 battery died and having issues locating a Tuasa YTZ10S. Can anyone who has used another battery recommend one please? Many thanks Quote Link to comment Share on other sites More sharing options...
manxie49 Posted December 2, 2021 Share Posted December 2, 2021 Have you tried MDS batteries? They stock Yuasa Quote Link to comment Share on other sites More sharing options...
kaintxu Posted December 2, 2021 Author Share Posted December 2, 2021 29 minutes ago, manxie49 said: Have you tried MDS batteries? They stock Yuasa Yup, Out of stock like every other main supplier. There is one that ships from Germany, but that might take too long Quote Link to comment Share on other sites More sharing options...
fastbob Posted December 2, 2021 Share Posted December 2, 2021 1 hour ago, kaintxu said: Hi everyone, My tracer900 battery died and having issues locating a Tuasa YTZ10S. Can anyone who has used another battery recommend one please? Many thanks https://www.tayna.co.uk/motorcycle-batteries/types/ytz10s/ Quote Link to comment Share on other sites More sharing options...
Ian Frog Posted December 2, 2021 Share Posted December 2, 2021 Have a look on Wemoto website they usually list alternatives. I have used Motobatt without problems on several bikes. Cheers Ian Quote Link to comment Share on other sites More sharing options...
kaintxu Posted December 2, 2021 Author Share Posted December 2, 2021 51 minutes ago, Ian Frog said: Have a look on Wemoto website they usually list alternatives. I have used Motobatt without problems on several bikes. Cheers Ian Motobtt ones are slightly larger. Will the fit? Quote Link to comment Share on other sites More sharing options...
billy sugger Posted December 2, 2021 Share Posted December 2, 2021 (edited) Powerline do a equivalent battery. They're not bad, but cca is less than yuasa one Edited December 2, 2021 by billy sugger Quote Link to comment Share on other sites More sharing options...
billy sugger Posted December 2, 2021 Share Posted December 2, 2021 I replaced mine with a JMT battery. It's a direct replacement, and is apparently a yuasa battery made under licence Quote Link to comment Share on other sites More sharing options...
kaintxu Posted December 2, 2021 Author Share Posted December 2, 2021 28 minutes ago, billy sugger said: Powerline do a equivalent battery. They're not bad, but cca is less than yuasa one what is CCA? so JMT is good then, thanks for letting me know Quote Link to comment Share on other sites More sharing options...
billy sugger Posted December 2, 2021 Share Posted December 2, 2021 31 minutes ago, kaintxu said: what is CCA? so JMT is good then, thanks for letting me know CCA is cold cranking amps. A higher ampage means more power is available to start the bike in cold weather Quote Link to comment Share on other sites More sharing options...
fastbob Posted December 2, 2021 Share Posted December 2, 2021 5 hours ago, kaintxu said: Motobtt ones are slightly larger. Will the fit? Where did you get that idea from ? Quote Link to comment Share on other sites More sharing options...
fastbob Posted December 2, 2021 Share Posted December 2, 2021 1 hour ago, billy sugger said: CCA is cold cranking amps. A higher ampage means more power is available to start the bike in cold weather I don't think CCA is much of an issue on a four cylinder bike . On a Harley it's everything though . Quote Link to comment Share on other sites More sharing options...
fastbob Posted December 2, 2021 Share Posted December 2, 2021 5 hours ago, kaintxu said: Motobtt ones are slightly larger. Will the fit? Did you open the link I sent ? Quote Link to comment Share on other sites More sharing options...
billy sugger Posted December 2, 2021 Share Posted December 2, 2021 57 minutes ago, fastbob said: I don't think CCA is much of an issue on a four cylinder bike . On a Harley it's everything though . When it was cold at beginning of the year my bike would not start sometimes even with a fully charged battery. The powerline is only 130 amps, the correct cca should be 190,which is what the JMT is. I carry a booster pack and had to use it a few times just to get it to turn over enough to fire up Quote Link to comment Share on other sites More sharing options...
