Cool chick Posted December 8, 2021 Share Posted December 8, 2021 I've got problem with my back left side indicator it's very dull on my moped how do I fix this Quote Link to comment Share on other sites More sharing options...
Stu Posted December 8, 2021 Share Posted December 8, 2021 Hi and welcome to the forum First thing I would do is change the bulb they are cheap enough Quote Link to comment Share on other sites More sharing options...
Cool chick Posted December 8, 2021 Author Share Posted December 8, 2021 I've done that Quote Link to comment Share on other sites More sharing options...
Six30 Posted December 8, 2021 Share Posted December 8, 2021 3 minutes ago, Cool chick said: I've done that did you do it properly ? Quote Link to comment Share on other sites More sharing options...
Stu Posted December 8, 2021 Share Posted December 8, 2021 Did the problem start before or after the bulb change? Quote Link to comment Share on other sites More sharing options...
Mississippi Bullfrog Posted December 8, 2021 Share Posted December 8, 2021 It's probably a bad earth. There will be corrosion either in the bulb holder, in the wiring or where that indicator earth is attached to the frame. You can use a test wire from the bulb to a good earth to check. Quote Link to comment Share on other sites More sharing options...
TimR Posted December 9, 2021 Share Posted December 9, 2021 What bike is it ? If its an old old bike it may be 6v and if you put 12v in it will dim Quote Link to comment Share on other sites More sharing options...
