gpr50 ignition?
jimsoon
I've bought a Derbi gpr50 but the key has snapped in the ignition, i spoke to a bloke today and he said that other models like aprillia rs50s might fit, any body know for sure before i buy the wrong thing?
Easier said than done, but have you tried extracting it yet?
Possibles:
dribble of superglue on key remnant and try to let it set then slowly pull out...
Or . disassemble the barrel - but bear in mind you may need to put it back together ...
Depends at what point the key snapped off to an extent ... if you can see it life could be (very) slightly easier ....
But it will be a royal pain in the bum to extract it :roll:
good luck :wink:
im picking it up tomorrow, so i'll have a better idea then, but thanks for the advice the super glue sounds a good idea, i was thinking magnets but probably not be strong enough.
