tom90ando Posted January 12, 2022 Share Posted January 12, 2022 I have recently changed my chain and sprockets removing the clutch in the process. I have put the bike back together but when I try and go from neutral into first gear it isn't changing. It does change eventually but can take upto 5 minutes of trying. Second, third, fourth and fifth gear are working fine. My bike is a Lexmoto LXR 125 Quote Link to comment Share on other sites More sharing options...
TimR Posted January 12, 2022 Share Posted January 12, 2022 Did you remove any of the gear linkage mechanism ? You may not have aligned it correctly Quote Link to comment Share on other sites More sharing options...
Mississippi Bullfrog Posted January 13, 2022 Share Posted January 13, 2022 Is the clutch dragging slightly? Bike clutches usually show some drag due to their design but if the clutch isn't adjusted right selecting first will be harder. Quote Link to comment Share on other sites More sharing options...
