Guest Posted January 16, 2022 Share Posted January 16, 2022 So folks when I was servicing the tdm it decided to wee fuel on the floor. I jumped to the conclusion it was carb related. Today I took the tank and airbox off and it occurred to me the fuel was running down near the backing the tank (carbs being at the front parallel twin). So is it just fuel out the carbs running along a hose to the back or is there another likely culprit? Quote Link to comment Share on other sites More sharing options...
Guest Posted January 16, 2022 Share Posted January 16, 2022 Come to think of it it's running probably through a breather/ Overflow hose which route to the back of the engine. Quote Link to comment Share on other sites More sharing options...
Stu Posted January 16, 2022 Share Posted January 16, 2022 Normally overflow pipes come out at the bottom back of the engine Is there any overflow pipes on the carbs? It might just be a sticking float Quote Link to comment Share on other sites More sharing options...
Guest Posted January 16, 2022 Share Posted January 16, 2022 These two hoses route towards the back (bottom pic it's the hose connected to the T in-between the carbs. Have got replacement float needle and seals/ o rings so will pull the carbs and check. Quote Link to comment Share on other sites More sharing options...
iangaryprice Posted January 16, 2022 Share Posted January 16, 2022 Stripping the carbs is quite a big job. I would look to check the leak is not from the tank/tap/fuel lines first. I have had 2 fuel leaks on my bike. 1. The water drain pipe from the fuel filler cap recess through the centre of the tank and out through the bottom, it had a rubber drain hose connectd to it that went down and exited near the centre stand, fuel was leaking onto the floor. I had to get a new pipe soldered in tot he tank. 2. The rubber fuel hose from the tap to the carbs perished. Simple repair, new hose and alos fitted a new inline filter at the same time. Both times I initially suspected leaking float valves (I bought spares which are still unused). Quote Link to comment Share on other sites More sharing options...
Guest Posted January 16, 2022 Share Posted January 16, 2022 Cheers @iangaryprice will double check all that first, would like to avoid carb fiddling if I can. The leak was only when running and was a significant amount of fuel. Considering connecting an auxiliary fuel supply and turning it over to see if I can see where its coming out. Quote Link to comment Share on other sites More sharing options...
Bender Posted January 16, 2022 Share Posted January 16, 2022 I would have some nice cloth stuffed exactly where when you drop something it's going to go 1 Quote Link to comment Share on other sites More sharing options...
iangaryprice Posted January 16, 2022 Share Posted January 16, 2022 1 hour ago, goat said: Cheers @iangaryprice will double check all that first, would like to avoid carb fiddling if I can. The leak was only when running and was a significant amount of fuel. Considering connecting an auxiliary fuel supply and turning it over to see if I can see where its coming out. Good plan. Quote Link to comment Share on other sites More sharing options...
iangaryprice Posted January 16, 2022 Share Posted January 16, 2022 1 hour ago, goat said: Cheers @iangaryprice will double check all that first, would like to avoid carb fiddling if I can. The leak was only when running and was a significant amount of fuel. Considering connecting an auxiliary fuel supply and turning it over to see if I can see where its coming out. Remember that most fuel taps are vacuum controlled so are only open when the engine is running. So seems your tap is working OK. With e leask I had 1, leaked all the time if tank was mor ethen 1/2 full. 2. Only leaked when engien was running. Quote Link to comment Share on other sites More sharing options...
Guest Posted January 17, 2022 Share Posted January 17, 2022 7 hours ago, iangaryprice said: Remember that most fuel taps are vacuum controlled so are only open when the engine is running. So seems your tap is working OK. With e leask I had 1, leaked all the time if tank was mor ethen 1/2 full. 2. Only leaked when engien was running. It's not vacuum operated, as I found out when I assumed it was and disconnected it and later found the manual fuel cut off Quote Link to comment Share on other sites More sharing options...
Guest Posted January 21, 2022 Share Posted January 21, 2022 Fuel was coming out of here carbs look a pain to remove, can't see how to disconnect choke cable, it has coolant running to them so need to clamp and remove those hoses as well. Quote Link to comment Share on other sites More sharing options...
Stu Posted January 21, 2022 Share Posted January 21, 2022 35 minutes ago, goat said: Fuel was coming out of here carbs look a pain to remove, can't see how to disconnect choke cable, it has coolant running to them so need to clamp and remove those hoses as well. The coolant pipes don't always run in to the carbs they sometimes just run to the carb and heating some copper parts to warm the carb up in cold weather these usually are bolted on and easily removed so check that first It will save draining any coolant if thats the case That pipes is an overflow by the looks of it so you have a sticking float I reckon Quote Link to comment Share on other sites More sharing options...
Guest Posted January 21, 2022 Share Posted January 21, 2022 Have detached the coolant hose, was attached at bottom of carb with a hose clip. Clamped it, pulled it off and have cable tied it up out the way and unclipped. Think there is just the one that I can see. Just got to work out clutch and throttle cables. Have got a haynes but it mainly relates to earlier models which had a different layout so none of the pics make any sense Quote Link to comment Share on other sites More sharing options...
Stu Posted January 21, 2022 Share Posted January 21, 2022 20 minutes ago, goat said: Have detached the coolant hose, was attached at bottom of carb with a hose clip. Clamped it, pulled it off and have cable tied it up out the way and unclipped. Think there is just the one that I can see. Just got to work out clutch and throttle cables. Have got a haynes but it mainly relates to earlier models which had a different layout so none of the pics make any sense I would suspect two pipes! one in and one out to complete the circuit Quote Link to comment Share on other sites More sharing options...
Guest Posted January 21, 2022 Share Posted January 21, 2022 14 minutes ago, Stu said: I would suspect two pipes! one in and one out to complete the circuit I'll investigate over the weekend Quote Link to comment Share on other sites More sharing options...
Guest Posted January 21, 2022 Share Posted January 21, 2022 The old brain is starting to warm up. I've removed the outlet and have found the inlet which ts off a coolant hose. Just got to see how to detach from the carb. Also remembered how throttle cables work so just the choke cable to sort. Quote Link to comment Share on other sites More sharing options...
Guest Posted January 23, 2022 Share Posted January 23, 2022 Carbs now off, one float is definitely slow in moving and the same carb has got a bit of jelly stuff in the float bowly bit. Quote Link to comment Share on other sites More sharing options...
