Philbo Posted June 23, 2022 Share Posted June 23, 2022 Hi,my son in law owns a 2012 triumph triple,chain come off recently.We called a local motorcycle repair shop.They recovered the bike,and fitted new sprockets plus chain.Son in law went for mot in London,and it failed on chain being too tight ?.He was told that they (mot station),could not understand how chain could have been fitted so tightly.Apparently it was 4 links too short?.He has been riding regularly on it recently,and had no problems.Any advice pls,thanks. Quote Link to comment Share on other sites More sharing options...
rightstuff Posted June 23, 2022 Share Posted June 23, 2022 To be honest can't see it being 4 links to short you wouldn't get it on Quote Link to comment Share on other sites More sharing options...
billy sugger Posted June 23, 2022 Share Posted June 23, 2022 I was just thinking that. 4 links is what, 4 inches roughly so wheel would be all the way forward in swing arm, even then I still doubt the chain could have been joined Quote Link to comment Share on other sites More sharing options...
MikeHorton Posted June 23, 2022 Share Posted June 23, 2022 Get your son in law to measure the chain slack and check to see if it matches the manual I think mine is about 40mm of slack, its something as a rider he need to do regularly maybe once a month and oil every 400 miles or so. Quote Link to comment Share on other sites More sharing options...
Ian Frog Posted June 23, 2022 Share Posted June 23, 2022 4 links too short wouldn`t fit on my Triumph so my suspicion starts to lean toward the place in London trying to drum up business ! As suggested measure the slack as I believe 4 links too short will be more like a guitar string. Cheers Ian 1 Quote Link to comment Share on other sites More sharing options...
onesea Posted June 24, 2022 Share Posted June 24, 2022 All seems a bit iffy to me why did the chain come off in the first place? the other option is has someone played with the cog size set up? your just demonstrating why many choose to do there own maintenance, finding good mechanics is a challenge. I am also not certain how much chain set up is in the MOT wear and tare yes. Cogs and chain and chain set up if in good condition and not dangerous should pass. Although I am not a MOT tester. Quote Link to comment Share on other sites More sharing options...
Philbo Posted June 24, 2022 Author Share Posted June 24, 2022 Thanks guys,he's due up today,will see if I can get more info.The guys who fitted new chain/cogs up here seem pretty genuine people,so I suspect the mot station is the culprit.Many thanks. Quote Link to comment Share on other sites More sharing options...
MikeHorton Posted June 24, 2022 Share Posted June 24, 2022 Measure it up to see if it's correct and it's worth buying a chain alignment tool, you can get some perfectly good metal ones for abput a fiver or a gucci laser one for about £50. Your chain provides your drive so it's important to check it and know how to maintain it or buy a shaft drive Quote Link to comment Share on other sites More sharing options...
Mickly Posted June 24, 2022 Share Posted June 24, 2022 (edited) 1 hour ago, MikeHorton said: Measure it up to see if it's correct and it's worth buying a chain alignment tool, you can get some perfectly good metal ones for abput a fiver or a gucci laser one for about £50. Your chain provides your drive so it's important to check it and know how to maintain it or buy a shaft drive Surely if you buy a bike with shaft drive it is also important to check it and know how to maintain it? Edited June 24, 2022 by Mickly Quote Link to comment Share on other sites More sharing options...
MikeHorton Posted June 24, 2022 Share Posted June 24, 2022 2 hours ago, Mickly said: Surely if you buy a bike with shaft drive it is also important to check it and know how to maintain it? Very true but not so much maintaining to do Quote Link to comment Share on other sites More sharing options...
Mississippi Bullfrog Posted June 25, 2022 Share Posted June 25, 2022 10 hours ago, MikeHorton said: Very true but not so much maintaining to do Where's the fun in that? Motorbikes are there to be tinkered with. 2 Quote Link to comment Share on other sites More sharing options...
Gerontious Posted June 25, 2022 Share Posted June 25, 2022 I will only miss the shaft on my old BMW when it comes time to replace the chain and sprockets on the Africa Twin. I’m guessing it will cost a tad more than the £10 oil and crushwasher change on the Beemer. 1 Quote Link to comment Share on other sites More sharing options...
MikeHorton Posted June 25, 2022 Share Posted June 25, 2022 And nice oily hands from a dirty chain too Quote Link to comment Share on other sites More sharing options...
MikeHorton Posted June 25, 2022 Share Posted June 25, 2022 Just now, Gerontious said: I will only miss the shaft on my old BMW when it comes time to replace the chain and sprockets on the Africa Twin. I’m guessing it will cost a tad more than the £10 oil and crushwasher change on the Beemer. How is the wear on yours I'm hardly having to adjust the chain on mine which is good news Quote Link to comment Share on other sites More sharing options...
Gerontious Posted June 25, 2022 Share Posted June 25, 2022 No adjustment since the first running in service. Though I am careful with lubing. (Gear oil) 1 Quote Link to comment Share on other sites More sharing options...
MikeHorton Posted June 25, 2022 Share Posted June 25, 2022 33 minutes ago, Gerontious said: No adjustment since the first running in service. Though I am careful with lubing. (Gear oil) That's good to hear, I've used the profi drylube in the summer and revert to gear oil for winter one is expensive the other cheap but both work and the profi stuff is non sticky and doesn't fling Quote Link to comment Share on other sites More sharing options...
