Bender Posted June 29, 2022 Share Posted June 29, 2022 From this month all ev chargers have to be smart, ie the charging of your car or bike can be controlled by the grid Worse the electric can be pulled from your car, you get a pittance in renumeration, worse again this is stealing valuable charge cycles from your vehicle. If you change cars every 2yr or so its prob not an issue if it has to last like ours will have to when we switch they can fook right off https://thirdrockenergy.co.uk/products/type-2-to-commando-plug-ev-portable-charger-with-lcd-screen-8a-to-32a-variable-7-4kw-5-metre?variant=37347601776793¤cy=GBP&utm_medium=product_sync&utm_source=google&utm_content=sag_organic&utm_campaign=sag_organic&utm_campaign=gs-2020-05-12&utm_source=google&utm_medium=smart_campaign&gclid=Cj0KCQjw8O-VBhCpARIsACMvVLNNk1Rika1KOeYHCV4biwEwrc4wI0RhRlLQ3bKP7tTVzFfx_JhlH0AaAtq3EALw_wcB Just so happens I have a 32amp socket outside for my welder as will any house me and my welder move too. 1 2 Quote Link to comment Share on other sites More sharing options...
Fiddlesticks Posted June 29, 2022 Share Posted June 29, 2022 Smart meters. The future. Someday soon, on a calm overcast day, when our green energy revolution is languishing in bed with a hangover and there aren't enough gigawatts to go around, a man in a room in Central London filled with cigar smoke and lit by old-fashioned light bulbs will issue the immortal words, "turn off Halifax". 4 Quote Link to comment Share on other sites More sharing options...
Mississippi Bullfrog Posted June 30, 2022 Share Posted June 30, 2022 Wouldn't work here. Smart chargers need a mobile signal and we don't have any. Plus I couldn't afford an electric car anyway. I'm just about able to manage an electric toothbrush. 3 Quote Link to comment Share on other sites More sharing options...
S-Westerly Posted July 1, 2022 Share Posted July 1, 2022 Quite how people are going to manage in rural areas I don't know. Expensive cars which probably can't be charged easily and a virtually nonexistent public transport network. Sounds like a winning combination. 1 Quote Link to comment Share on other sites More sharing options...
Mississippi Bullfrog Posted July 1, 2022 Share Posted July 1, 2022 4 hours ago, S-Westerly said: Quite how people are going to manage in rural areas I don't know. Expensive cars which probably can't be charged easily and a virtually nonexistent public transport network. Sounds like a winning combination. Apparently we have these things called horses that run on grass. They look pretty dangerous to me, I don't fancy hurtling along country roads at 5mph with no brakes and dodgy steering. 4 Quote Link to comment Share on other sites More sharing options...
S-Westerly Posted July 1, 2022 Share Posted July 1, 2022 Can't stand the bloody things (horses) myself. Have to revert to medieval peasant lifestyle and travel as far as I can walk. Meanwhile in China they don't give a toss about the environment whatever platitudes they might mouth in public. Officially no grit blasting allowed - on occasion like walking in a sandstorm due to dust from grit blasting. Only time I was glad to wear a mask. Being environmentally minded the owners changed from one kind of Freon Gas to a more benevolent variety. Chinese techs carefully captured the old gas into empty cylinders and then equally carefully allowed them to leak to atmosphere overnight. Etc. Etc. 1 1 Quote Link to comment Share on other sites More sharing options...
MikeHorton Posted July 1, 2022 Share Posted July 1, 2022 How do you plug in these modern horse thingys? 2 Quote Link to comment Share on other sites More sharing options...
Bender Posted July 1, 2022 Author Share Posted July 1, 2022 1 hour ago, MikeHorton said: How do you plug in these modern horse thingys? Don't knock the horsey cloppety things, remember they are great at hauling drays 1 Quote Link to comment Share on other sites More sharing options...
Stu Posted July 1, 2022 Share Posted July 1, 2022 2 hours ago, MikeHorton said: How do you plug in these modern horse thingys? Theres a charging port under the tail............ 1 Quote Link to comment Share on other sites More sharing options...
Bender Posted July 1, 2022 Author Share Posted July 1, 2022 Just now, Stu said: Theres a charging port under the tail............ Bollocks...... 1 Quote Link to comment Share on other sites More sharing options...
Stu Posted July 1, 2022 Share Posted July 1, 2022 Just now, Bender said: Bollocks...... No! not that far under! Quote Link to comment Share on other sites More sharing options...
Bender Posted July 1, 2022 Author Share Posted July 1, 2022 5 minutes ago, Stu said: No! not that far under! I'm not from ull I've only seen them on TV Like to see you charge samson up 1 Quote Link to comment Share on other sites More sharing options...
fullscreenaging Posted July 1, 2022 Share Posted July 1, 2022 Looks like they had photoshop back then Quote Link to comment Share on other sites More sharing options...
Bender Posted July 1, 2022 Author Share Posted July 1, 2022 1 minute ago, fullscreenaging said: Looks like they had photoshop back then Biggest recorded horsey thingy int world Quote Link to comment Share on other sites More sharing options...
skyrider Posted July 1, 2022 Share Posted July 1, 2022 1 hour ago, Bender said: Bollocks...... the stuff that comes out is good for putting on your roses Quote Link to comment Share on other sites More sharing options...
Guest Posted July 1, 2022 Share Posted July 1, 2022 9 minutes ago, skyrider said: the stuff that comes out is good for putting on your roses Depends how well you tickle the bollocks. So I heard. Quote Link to comment Share on other sites More sharing options...
JRH Posted July 3, 2022 Share Posted July 3, 2022 On 30/06/2022 at 18:43, Mississippi Bullfrog said: Wouldn't work here. Smart chargers need a mobile signal and we don't have any. Plus I couldn't afford an electric car anyway. I'm just about able to manage an electric toothbrush. Have you seen the price on electric toothbrushes. Needed a new one and checking out Boots website they have top of the range Oral-B brushes at £500.00. 1 2 Quote Link to comment Share on other sites More sharing options...
Mississippi Bullfrog Posted July 3, 2022 Share Posted July 3, 2022 41 minutes ago, JRH said: Have you seen the price on electric toothbrushes. Needed a new one and checking out Boots website they have top of the range Oral-B brushes at £500.00. What! Mine is dying. I'm not paying that for a toothbrush even if it is gold plated. Quote Link to comment Share on other sites More sharing options...
JRH Posted July 3, 2022 Share Posted July 3, 2022 4 hours ago, Mississippi Bullfrog said: What! Mine is dying. I'm not paying that for a toothbrush even if it is gold plated. I replaced mine with a brush from Argos by using my Nectar points. Quote Link to comment Share on other sites More sharing options...
Bender Posted July 3, 2022 Author Share Posted July 3, 2022 Think I will just stick with manual version Quote Link to comment Share on other sites More sharing options...
Mississippi Bullfrog Posted July 4, 2022 Share Posted July 4, 2022 8 hours ago, JRH said: I replaced mine with a brush from Argos by using my Nectar points. That's a good idea. I have a few quid in points. Quote Link to comment Share on other sites More sharing options...
Mississippi Bullfrog Posted July 4, 2022 Share Posted July 4, 2022 8 hours ago, Bender said: Think I will just stick with manual version Luddite. Quote Link to comment Share on other sites More sharing options...
S-Westerly Posted July 4, 2022 Share Posted July 4, 2022 My wife has an electric toothbrush and I just don't see the point. I use a manual one and I don't think it makes that much difference. Quote Link to comment Share on other sites More sharing options...
MikeHorton Posted July 4, 2022 Share Posted July 4, 2022 At so point I may end up with false teeth when I'm older. I'll be able to take them out and brush them whilst watching TV Quote Link to comment Share on other sites More sharing options...
Mississippi Bullfrog Posted July 4, 2022 Share Posted July 4, 2022 1 hour ago, S-Westerly said: My wife has an electric toothbrush and I just don't see the point. I use a manual one and I don't think it makes that much difference. My dentist seems to know the difference. When I switched from manual to electric she knew before I told her. 1 Quote Link to comment Share on other sites More sharing options...
