Guest Posted July 21, 2008 Posted July 21, 2008 hey , i took my motorbike out yesterday and it wouldnt reach top speed . once in full throttle is would make a loud poping noise from the exhaust , cuts out alot.every now and then it would get burst of speed but then goes back to slow and makes the poping noise.would this be due to a missfire or something else ??please help Quote
Voodoo Posted July 21, 2008 Posted July 21, 2008 Try changing the spark plugs, sounds like its not burning the fuel sometimes, hence the pop when it does eventually ignite. Quote
Guest akey Posted July 21, 2008 Posted July 21, 2008 could be:Old fuel (has the bike stood for a while?)Spark plugsHT leadsCoils Quote
Guest Posted July 21, 2008 Posted July 21, 2008 Check your plug leads are connected,have you taken them off recently if so check there on in the correct firing order,had the same myself the other week after i serviced the bike,had 2 leads the wrong way roundOh while you at it pop into newbies and introduce yourself Quote
Sam The Man Posted July 22, 2008 Posted July 22, 2008 Sounds similar to my problem ( viewtopic.php?t=13182 ) which i think it is the spark plug Quote
