Guest Posted August 15, 2008 Posted August 15, 2008 hey i got this here bike and everytime i fix something it has a new problem....when i start it up has a rough time startin but when she finally does it cuts out and pops fireballs under my seat...also me friggin tailpipe gets red hot providin i set the carb line to left , left pipe gets hot. right side of carbs right pipe gets hot...damn twin engine...anyone have any advice i'd be stoked as i have low mech skill. Quote
Guest Posted August 15, 2008 Posted August 15, 2008 plug leads in wrong order ? what have you done to the bike ? Quote
Guest Posted August 15, 2008 Posted August 15, 2008 pretty much cleaned the fella up some bought some carb cleaner crap which didn't do much...i dunno what the thing is u just said but if u reply again im on a laptop so i can find it...the dude i bought it off of said she was sittin for some 2 years or so...so i cleansed it as best i could without goin where im not sposed too Quote
Guest Posted August 15, 2008 Posted August 15, 2008 i dunno what the thing is u just said but if u reply again You mean Plug Leads ?Spark plug leads make sure that you have them on the correct plug * your manual wil help you with that possibly)as for carb cleaner i is good stuff but some cheaper varieties are a bit but if you strip the carb down and use it and leave it to soak a bit generally works best ... Did you reset the carb tuning to as it was beforw you stripped it Did the bike run before >? Quote
Guest Posted August 16, 2008 Posted August 16, 2008 i dun have a manual it totally sucks..umm i think the spark plug cables are where they are...umm i guess that could fix it...i adjusted the air intake screw things below snug tight then 1 and a half turns back? think thats right... Quote
Guest Posted August 16, 2008 Posted August 16, 2008 oh carb line...well my petcock valve has 2 hose connections 1 for the fuel line and another that goes to either left or right side of the carbs to prime...problem is when i hook it in it makes say its in the left side...the left tailpipe gets red hot...and if in right right side gets hot. i hate this bike more then sweet pickles...yet ....i must fix it! just to say the biggest F U _ K YOU! Quote
Guest Posted August 24, 2008 Posted August 24, 2008 alright so i fixed that problem and much more...now i have the last problemi had the bike runnin perfect except now the gas just goes right out the overflow line and drains the tank...any advice? Quote
flipper Posted August 25, 2008 Posted August 25, 2008 stuck float. split diaphragm. wrongly connected carbs. Quote
Guest Posted August 28, 2008 Posted August 28, 2008 yay none caused by me YES i can blame the mechanic and get it fixed for free thx duder! Quote
