Stewart Patient Posted August 30, 2023 Posted August 30, 2023 Hi all, I've recently heard of an airbox mod but don't know anything about it. any info would be appreciated. Thanks. Quote
Guest Posted August 30, 2023 Posted August 30, 2023 No idea but carpe-tdm forum would be a good place to ask if folks on here don't know. Quote
RideWithStyles Posted August 30, 2023 Posted August 30, 2023 Agree with goat, good luck with finding the info you want. Most of the times its removing plates/deflections, changing pipe orientation, drilling holes into the air box, right up to junking the top clam of the airbox and using the tanks as its crude cover so that a will allow for more volume which is fine if you can go full speed all the time but for road use and to a point even off road use creates bigger problems than solving anything in the first place. Quote
