Hi and welcome to the forum
Yes there should be a seal there that can be changed
But first have you cleaned up the whole area to make sure its leaking as chain lube can make it look like a leak
  • Thanks 1
Posted (edited)
As Stu suggested clean off the area and make sure that there is a leak and not just chain oil / grease
If there is a leak there is an oil seal behind the sprocket and another site suggests it is part no  https://ie.fowlersparts.co.uk/parts/view/T3600112 and
Cheap as chips at 8 quid
https://www.thetriumphforum.com/threads/front-sprocket-oil-leak.31037/
Edited by V650
