redtailkarn Posted August 30, 2008 Share Posted August 30, 2008 hi, I've got a promblem with my speedo on my zx9r c1. It reads about 6-10 mph out. So if it reads 22 I'm actually doing about thirty. not good since i've only recently passed my test, and i do want to keep my liecence. I intend to get a manual today but if anyone can help it would be appreciated. Oh one thing, the sprockets are standard I don,t know if this could cause a problem but jusy thought i'd say. cheers mick Quote Link to comment Share on other sites More sharing options...
Bill_on_a_bike Posted August 30, 2008 Share Posted August 30, 2008 YEY you're from hertfordshire.Standard sprockets shouldn't be a problem if they're standard. I'm not sure what it might be, if it's digital then i guess it's either the speedo drive (wherever it might be) or the clock itself.If it's a mechanical speedo then it could be the cable? I'm not sure Quote Link to comment Share on other sites More sharing options...
redtailkarn Posted August 30, 2008 Author Share Posted August 30, 2008 hi, yes St. Albans in herts The Trip meter, odo meter is digital, but the clock is what i'd guess machanical. I've look for a cable but cant find one, thats why I'm off to get a manual. however looked on ebay and they have cables for all zx9r modles, I'm confused. cheers Quote Link to comment Share on other sites More sharing options...
Bill_on_a_bike Posted August 30, 2008 Share Posted August 30, 2008 Now i'm trying to think of places in St Albans i've seen ZX9s.The speedo drive might run from your front wheel, in which case there'll be a cable running out from either side of the wheel spindle.Or like you say it can run off the rear sprocket i think, or the rear wheel. If it's mechanical it's usually a bit chunkier than other cables. Quote Link to comment Share on other sites More sharing options...
Guest Posted August 30, 2008 Share Posted August 30, 2008 Are you sure you don't have a KPH speedo rather than an MPH speedo? Is your bike an official import or is it from a different country? Quote Link to comment Share on other sites More sharing options...
Guest Posted August 30, 2008 Share Posted August 30, 2008 ignore my last post, if it was KPH it would be out in the other direction soz Quote Link to comment Share on other sites More sharing options...
Guest Posted September 3, 2008 Share Posted September 3, 2008 is the difference always the same or does it get bigger orsmaller the faster you go. I can't see the problem being a cable as all it would do is spin around , calibration on speedo could be out (could be different one fitted from original). My mini always runs out because it has a 1275 engine instead of the standard 1000. Try to see if anything has been replaced, ask previous owner what they know, this could save a lot of investigation Quote Link to comment Share on other sites More sharing options...
Stu Posted September 4, 2008 Share Posted September 4, 2008 i think the drive is on the front wheel on the zx9 and it sounds like you have a worn drive Quote Link to comment Share on other sites More sharing options...
redtailkarn Posted September 4, 2008 Author Share Posted September 4, 2008 Thanks for the replies, I Think the speed is constantly out however i can't be 100 percent sure as I've only really check it a couple of times and only up to about fourty. I know it's not a sprocket problem, the rear sprocket is standard and I've done my maths and a front sprocket on it's own can't make that much difference. Apparently my zx9r 98 c1 doesn't have a speedo cable, it's electric something to do with magnets. I have now got a manual and trying to work things out. I now think, either the sensors knackered or may be as you said there's something wrong at dail end. I have call the old owner and he didn't know it was out, I've now got a sat nav so can get a more accurate reading instead of following or being followed. but stil need it sorted. My mate with a c2 said that if it's not a big problem and the same sensor, we can take his and fit it to mine to eliminate or comfirm weather thats the problem. the saga continues Quote Link to comment Share on other sites More sharing options...
Stu Posted September 4, 2008 Share Posted September 4, 2008 if it is electric then it should be on the front sprocket cover check to make sure its secure and also check that the connectores are clean and dry mine got water in before and was under reading then over reading then just stopped hope that helps Quote Link to comment Share on other sites More sharing options...
rosszx9r Posted September 5, 2008 Share Posted September 5, 2008 the speedo drive is always on the front wheel unless your talking about some odd ball bike which your not look for the bike black cable coming from the front hub (about 8mm in diameter)if it is a digital pickup then it will be a small wire but again coming from the front hub.usually, all speedo's read faster than you are actually going. how did you check it? the only real way is to have a mate follow you in a carr and both note the speed at a certain point or to use a GPS. GPS is best as the car speedo will also be out.the sprocket has nothing to do with the speedo so don't worry about that. the sprocket only regulates the speed of the back wheel not the speed of the bike (although the two are directly linked along with a dozon other parameters)it all is working ok and the speedo is still reading slow, the diameter of the front wheel may of changed. is it the origonal wheel? check the size. does it have a lower or larger than normal profile?tyre wear won't make a significant change but if a 16" is swaped for a 17" then it certainly could.failing all that, send the speedo off for a refurb. there are plenty of companies doing it if you look through MCNyou can inspect the magnet pickup device by dropping the front wheel out. it's really easy. the speedo drive should just drop out once the wheels off. Quote Link to comment Share on other sites More sharing options...
