Guest Posted August 31, 2008 Share Posted August 31, 2008 mi 100cc electric start wont work i press it and nothing whats up Quote Link to comment Share on other sites More sharing options...
Guest Posted August 31, 2008 Share Posted August 31, 2008 could my battery need charging Quote Link to comment Share on other sites More sharing options...
softwarez Posted August 31, 2008 Share Posted August 31, 2008 Do you hear a click?If not.. Could be flat battery, or check the cable going to the starter relay. Quote Link to comment Share on other sites More sharing options...
Guest Posted August 31, 2008 Share Posted August 31, 2008 no nothing i press it and nothing ?????can i charge battery with charger with a female clip on it Quote Link to comment Share on other sites More sharing options...
Guest Posted August 31, 2008 Share Posted August 31, 2008 i checked cables they seem fine Quote Link to comment Share on other sites More sharing options...
Guest Posted August 31, 2008 Share Posted August 31, 2008 i meen can i use a charger with a male clip on it my battery has female clip Quote Link to comment Share on other sites More sharing options...
softwarez Posted August 31, 2008 Share Posted August 31, 2008 Not quite sure what you mean... :SAslong as you connect the charger, Positive ( + ) to Positive ( + ) and Negative ( - ) to Negative ( - ) Quote Link to comment Share on other sites More sharing options...
Guest Posted August 31, 2008 Share Posted August 31, 2008 my battery has a wite clip that the current clip goes into ill get a pic if you want do you want a pc of charger and bateery Quote Link to comment Share on other sites More sharing options...
Guest Posted August 31, 2008 Share Posted August 31, 2008 heres pic of charger Quote Link to comment Share on other sites More sharing options...
Guest Posted August 31, 2008 Share Posted August 31, 2008 ill try charge it and ill let you no if its sorted or if i need more help Quote Link to comment Share on other sites More sharing options...
Guest Posted September 3, 2008 Share Posted September 3, 2008 looks like 3 leads in the packet if so thats messed up, should only be 2 red always to positive the other to negative. Fix them however you can (hammer and nail maybe ) Quote Link to comment Share on other sites More sharing options...
Guest Posted September 4, 2008 Share Posted September 4, 2008 there is a safty thing on back brake so it needs to be pessed but someone has cut wire, were oes the wire go to from brake Quote Link to comment Share on other sites More sharing options...
Guest Posted September 4, 2008 Share Posted September 4, 2008 ok about te safty thing i forund it it came off Quote Link to comment Share on other sites More sharing options...
Guest Posted September 25, 2008 Share Posted September 25, 2008 it might not be anything to do with your battery it sounds to me like the button wires are no connected behind it or somewhere along the wiring theres no connection. try taking of the pannel or cover to get to behidn the button see if its all connected Quote Link to comment Share on other sites More sharing options...
