If everything was put back together properly and tightened up it could be a buckled wheel caused by a Guerilla changing the tire or wheel bearings failing.
Take it back and see what they say.
It might not have been balanced correctly.
Whatever the issue it had to have happened there as it was ok before you had the tyre changed.
Check the rim to make sure its straight first
It could just be the tyre not seated correctly
Thanks guys - let me double check the bead on the rim. It looked like it was ok but was a bit dark.
23 minutes ago, RideWithStyles said:
its not the tyre.
the wheel directly or the hub/bearing seat as the sprocket and chain is moving side to side along with the wheel!!!
Ah I thought the side to side on the sprocket + chain was normal due to the rubber bushing in there
Posted (edited)
chain and sprocket should run true!
carrier/crush is not seated correctly or very worn out.
either way id give it back to them to actually do the job properly the second time around, for a dealership that's terrible.
Edited by RideWithStyles
