Ingah Posted October 3, 2008 Posted October 3, 2008 Was just wondering if any of you could shed some light on the little issue i have with my poor little CG - no harm in asking i'm thinking:Its an 02 plate i've owned since December 07, for the last 7K miles (its done about 21K in total now, i think), and its always 'cluncked' when changing between lower gears (especially neutral to gear 1/neutral to gear 2/gear 1 to gear 2).Its just that i think the problem has slowly got a little worse over my ownership, with louder cluncking. It also occasionally fails to change between these cluncky gears correctly - although this is thankfully a rare occurance. The bike also seems to 'grab' (for want of a better word) very slightly when the throttle is closed slightly whilst in motion. I don't know if the two are related.Someone mentioned clutch drag on a post on here regarding a gearbox issue - i have no idea what this is about but i'm sure some on here will be able to tell me whether it could be something to do with it Quote
Guest Posted October 3, 2008 Posted October 3, 2008 hmm have you adjusted the clutch in all the time owned ? Quote
Bill_on_a_bike Posted October 3, 2008 Posted October 3, 2008 Got very simular symptoms with the SR lately, so i'll be watching this one closely.Got my first proper day off for a while tomorrow, so i'm going to give the bike a really good check over, chain tension will be on the to do list. Quote
