TomW Posted October 9, 2008 Posted October 9, 2008 How do you tell when your carbs are unbalanced i've just de-restricted my bike and now its not running right im getting a couple of flat spots higher up in the revs, i spoke to a mechanic briefly today and he said it could be the carbs was just wondering what the symptoms were? Cheers, Tom. Quote
Stu Posted October 9, 2008 Posted October 9, 2008 carb balance only rally effects the slow running of the bike not at high revs it balances out the amount of air been sucked into each pot an eratic rev counter is a sign of out of balance carbs but my guess would be you need the bike setting up properly have you got a aftermarket exhaust on ? if so stick the origanal one on and see how it is Quote
TomW Posted October 9, 2008 Author Posted October 9, 2008 carb balance only rally effects the slow running of the bike not at high revs it balances out the amount of air been sucked into each pot an eratic rev counter is a sign of out of balance carbs but my guess would be you need the bike setting up properly have you got a aftermarket exhaust on ? if so stick the origanal one on and see how it is nope standard egg sauce, think i may have to chuck it in the garage and let them fix it! Quote
Guest nigelf Posted October 9, 2008 Posted October 9, 2008 If it had an air flow restriction fitted it probably will need to be re jetted (little bits in the carb)What colour are the plugs..if they are VERY light in colour you may be running very lean as you have more air goting through the engine now.Elf Quote
TomW Posted October 9, 2008 Author Posted October 9, 2008 haven't managed to get a plug out yet as their so bloody hard to get too, i've spoken to the people who restricted it and they said that the jetting wasnt touched will it still need rejetting? Quote
Stu Posted October 9, 2008 Posted October 9, 2008 jetting isnt touched when they restrict them could have just been like that before the restriction Quote
TomW Posted October 10, 2008 Author Posted October 10, 2008 jetting isnt touched when they restrict them could have just been like that before the restriction yeah i thought that but when it was restricted it ran fine very smooth you couldnt really tell that it was restricted. so just seems a little weird! Quote
