Guest Posted October 19, 2008 Posted October 19, 2008 When the rear brakes are operated they hold on,any advice on freeing up these my old legs haven't the strength to push the bike like they used to.If you push the operating arm back every thing is OK but what lbrication should a newby use.Viv Quote
Stu Posted October 19, 2008 Posted October 19, 2008 hi Viv welcome to the forum pop into newbies and introduce yourself first of all what bike is it ?and you also say push the operating arm back and its OK again do you mean the brake pedal is sticking down ? and when you pull it up the brakes are releasing ? Quote
Guest Posted October 19, 2008 Posted October 19, 2008 Sorry not used to forums.The bike is a Suzuki 125 Avenger.The brake pedal returns OK its the operating arm on the drum that isn't returning,I supose that the 2 springs on the end of the pads don't have enough pull to over come the fricsion.Just looking fr adviceViv Quote
Stu Posted October 19, 2008 Posted October 19, 2008 ah drums!!!! not really had much to do with drums but i would guess that a good strip and clean and grease moing parts will cure it Quote
Guest Posted October 19, 2008 Posted October 19, 2008 Could you recomend a type of grease being a newby I worry about grease and brakes.Viv Quote
Guest Posted October 19, 2008 Posted October 19, 2008 Its not an avenger, its a marauder 125Y w reg, sorry don't know where that came from! Quote
Stu Posted October 19, 2008 Posted October 19, 2008 any grease really copper grease would be better just dont get any on the shoes or drum Quote
Guest Posted October 19, 2008 Posted October 19, 2008 Thanks for your help ,wipped of the drum (not quite that easy) and its the cable the drum and gutts are all free so have ordered a new cable and will get some grease ad give it a go.thanks again.Viv Quote
Guest akey Posted October 19, 2008 Posted October 19, 2008 As Stu said copper grease. Give it all a good clean with degreaser then put some copper grease or copper slip (same stuff) on all the moving parts (not the surface of the brake pads) rebuild and it should all be good. Quote
Voodoo Posted October 19, 2008 Posted October 19, 2008 I'd say that its nothing to do with them been dirty and no amount of lubricating etc will cure it. Its due to the fact that the brake shoes are too worn. The only cure is to buy a new set of brake shoes. If you do it yourself, careful you don't trap your fingers in the springs, it hurts! Quote
Guest Posted October 19, 2008 Posted October 19, 2008 ok also with a drum brake if the chain has been adjusted it can also affect the rear brakes so when adjusting the chain slacken the rear brakes off and adjust up after doing the chain ... Quote
