Sam The Man Posted October 24, 2008 Posted October 24, 2008 I want to clean my 2 stroke fuel system. Anyone know any good products which can do this? I dont want to use redex as it just cleans the head etcThanks Quote
Voodoo Posted October 24, 2008 Posted October 24, 2008 Why do you need to clean it, whats the problem? Quote
fazerdai Posted October 24, 2008 Posted October 24, 2008 Why do you need to clean it, whats the problem? Thats a good question Quote
Guest philgale Posted October 24, 2008 Posted October 24, 2008 a thread about 2 strokes......fozzie will be along soon Quote
Sam The Man Posted October 24, 2008 Author Posted October 24, 2008 thanks stu...was gonna put it in there.Right, it cuts out when you are about 2-3 mins into a journey when it has first started up. The place where i got it serviced and bought it says that there could possibly be some dirt etc in the fuel system and be clogging up the jet, carb etc so I need to clean it out Quote
Voodoo Posted October 24, 2008 Posted October 24, 2008 Well if thats the case, then you could really do with an inline fuel filter, and then you could do with cleaning the carb out by taking it apart.Fuel Filter Quote
Sam The Man Posted October 25, 2008 Author Posted October 25, 2008 Well if thats the case, then you could really do with an inline fuel filter, and then you could do with cleaning the carb out by taking it apart.Fuel Filter Thanks for the link. I dont really know how to take carb out and put a fuel filter in etc and dont want to try it Quote
Voodoo Posted October 25, 2008 Posted October 25, 2008 The fuel filter is easy, just cut the tube that comes out the bottom of your tank and push both ends of the tube onto both ends of the filter. Quote
Guest Posted October 25, 2008 Posted October 25, 2008 The carb etc can be fiddly because of the tight fit but once you do it once it really isnt so scary and there's no more "oh god what if I take it apart and cant put it back together!" Quote
Voodoo Posted October 25, 2008 Posted October 25, 2008 The carb etc can be fiddly because of the tight fit but once you do it once it really isnt so scary and there's no more "oh god what if I take it apart and cant put it back together!" just don't adjust anything inside, and don't take out or move any of the adjustment screws. Quote
Sam The Man Posted October 26, 2008 Author Posted October 26, 2008 hmmm thanks guys. i dont really want to mess with anything as i am useless lol hanks anyway Quote
Grumpy Old Git Posted October 30, 2008 Posted October 30, 2008 The carb etc can be fiddly because of the tight fit but once you do it once it really isnt so scary and there's no more "oh god what if I take it apart and cant put it back together!" just don't adjust anything inside, and don't take out or move any of the adjustment screws. The carb can be stripped down quite easily, it you remove the throttle stop and mixture screws - just count how many turns to undo and use same number on re-assembly (WRITE THE NUMBERS DOWN). Any fine adjustment can easily be done once re-fitted and engine running (after warm-up). Set throttle stop for correct tick-over and adjust mixture screw for highest revs. adjust both till correct. Try 'snapping' open throttle, should not 'hesitate' if so, mixture still not quite correct (or your timing is out!).Othe parts of the carb just screw out and re-fit firmly (no adjustment) except the throttle slide / throttle needle - the needle can usually be fitted into the top of the slide in three positions - note which one its in and re-fit to same point.Do not use abrasives anywhere within the carb.Blow out channels using airAny emulsified fuel (brown sticky stuff) can usually be persueded to go away by washing in clean petrol (I've found model aircraft fuel especially good at this).Have a go - As long as you are careful, you will be OK.All the best Quote
Guest akey Posted October 30, 2008 Posted October 30, 2008 OK if your really dont want to take the carb apart then the next best option is to use Wynns Carb Cleaner (Its an aerosol spray).Take off the Air filter and run the bike on a very very high tickover, or about half throttle, then spray the carb cleaner directly into and around the carb inlet.Forthe rest of the fuel system, clean fuel is the best cleaner. Quote
Sam The Man Posted November 4, 2008 Author Posted November 4, 2008 OK if your really dont want to take the carb apart then the next best option is to use Wynns Carb Cleaner (Its an aerosol spray).Take off the Air filter and run the bike on a very very high tickover, or about half throttle, then spray the carb cleaner directly into and around the carb inlet.Forthe rest of the fuel system, clean fuel is the best cleaner. right, i may try that....thanks Quote
Sam The Man Posted November 4, 2008 Author Posted November 4, 2008 i could try this http://cgi.ebay.co.uk/ws/eBayISAPI.dll? ... otohosting Quote
slugworth1987 Posted November 5, 2008 Posted November 5, 2008 redX shot, 97 or 99oct fuel and a carb cleaning thing as said if you dont wanna strip it Quote
Sam The Man Posted November 6, 2008 Author Posted November 6, 2008 i got this the other dayhttp://www.halfords.com/webapp/wcs/stor ... yId_165750thanks guys Quote
