slight problem with the bike :(
Guest philgale
right i have suddenly doubled in age coz i fitted some heated grips today and can i just say......toasty :D
but the thing that holds the bar end weight on the throttle side has...well....come out its sat next to me right now
anyone any idea how to get it back in....
http://i294.photobucket.com/albums/mm99/tmbf_photos/barend.jpg
Guest philgale
erm.....think that might work to help me get it out not to keep it back in....
need to get it sorted before i set off on friday
I am guessing that the innermost part is threaded?
If so you will have to move the shaft about until the end locates the female thread and start tightening it up.
Are they both threaded the same way or is one a left-handed thread?
Guest philgale
the bit at the very bottom of the pic just below the black bit is where the screw screws :lol:
pic from other end,
http://i294.photobucket.com/albums/mm99/tmbf_photos/barend2.jpg
have you tried unscrewing the throttle switch box thing?
you may find it goes in from that end, then you add the bar-end back on after you've re-inserted it?
sorry I can't be more specific :D
Guest philgale
bugger....thought so
i dotn have a bloody clue how to do that tho :(
two screws underneath the black box with the emergency kill switch.
unscrew them, the bottom will come loose.
May be able to take throttle out that way.
I learnt how to put mine back together by dropping it... but I don't recommend you learn that way :)
I'd drive over tonight and help ye, but I've no fuel till tomorrow.
if you're still stuck tomorrow, I can come over after work?
Guest philgale
why do you work near me.....
i gotta work late tomorrow so will have to get up early friday and give it ago unless i risk doing it in the dark
Guest philgale
nah.. but I dont mind the trip over the hills...
lol....nice
oh well feel free tomorrow but i wont be home till about 8 :(
ah no.. wait.. they're held in by compression - stupid me!
loosen the screw thats "in" the barend... that releases the "pressure" build on that black bit in the middle.
once it's nice and loose.. GENTLY tap it back in with a plastic hammer / boot sole (:P)
once in.. re-tighten the bar-end end :D
and if that don't work, I don't mind coming over for 8 - I don't finish till 5.30 anyways.
if it don't work, send us your postcode ;)
Guest philgale
right.....but why did the bolt at the top of second pic just come out???
cos the "join" is too tight.
screw the nut back on.
Then... HOLDING the "fatter" tube tightly, unscrew the barend again.
the bar-end bit screws into the larger, fatter tube.
might be worth some WD40 on the "join"...
lemme see if I can get some pics
http://www.streetfightersinc.com/HesaOberonMirrorStreetFighterPair.jpg
http://www.tastynuts.com/acatalog/BARENDSUZ20.jpg
see how these barends have an "integral" bolt?
that's the bit that you need to unscrew from the "main" shaft tuby bit with all the black on.
Guest philgale
this is what it looks like undone
http://i294.photobucket.com/albums/mm99/tmbf_photos/barend3.jpg
is it still the same principle???
Guest philgale
lookin at it, if i just put it back in and then try and screw it up the other end would just spin so wouldnt tighten up
ok yes.. same principal.
The rubber bits should stop the main tube from spinning round, as they will grip the inside of the bar.
put it all back togehter again.
Do the main bolt up till it's finger tight, then give it half a turn with the wrench.
now.. insert the tube into the bar and tap it back down.
DONT grease it up, else the rubber will slip and you'll be fooked till it dries out.
once in, you should be able to tighten the bar-end side of the screw quite a bit, until it becomes very stiff.
What you're doing is "clamping" that big bit of rubber together, which forces it to push out sideways against the inside of the handlebar.
Once you've "clamped" it enough, the bar-end will be rock-solid in there..
Guest philgale
all fixed.......easy when you know how :lol:
thanks mate, i owe you a pint :D :cheers:
Guest philgale
pleasure me old mukka :)
:beer2:
glad you're sorted, and see you on Sunday :D
if you come to the ace the bacon butty is on me mate
By God!!! My son has become intelligent (at last!). Recently he asked me how I knew how to strip, clean & fix motorbike engines and 'stuff' - Told him it was by trial and error over many years. In fact, still learning but I still love to take things apart and see f I can fix them. @Fixed' an electronic power switch yesteday!
Good on you son!
Phil, if Ian can't make the Ace - Can I have his butty? :D
