Guest Posted November 6, 2008 Posted November 6, 2008 HiI have noticed that over the last couple of days only sometimes when I pull away in first and sometimes also in second and even with a warm engine that the engine is holding back a bit and then all of a sudden a burst of speed. Its annoying when it holds back and then a shock when it suddenly moves.Its fine at higher speeds no probs.I know the fuel filter probably needs a clean and the throttle grip/cables lubricating but does anyone think this problem is due to this or something else?Spark plugs were changed not that long ago and not due an oil change yet.CheersDaniel Quote
cyberwolf Posted November 6, 2008 Posted November 6, 2008 i take it this is with the ZZR 600? if it is the something wrong i would say its your carbs and i would say put a new fuel filter on if you can i don't really know akey or stu well be along soon they have more of a idea Quote
Bill_on_a_bike Posted November 6, 2008 Posted November 6, 2008 Sounds like a clutch thing to me, unless i've misunderstood. Quote
Stu Posted November 6, 2008 Posted November 6, 2008 possibly carb icing? hmmm i cant really see it been carb icing as this usually just kills the engine does it do it after you let off the throttle from a constant speed then go back on the throttle ?or just random Quote
techno Posted November 6, 2008 Posted November 6, 2008 My kwakka did that last winter when the weather was cold... i thought it might have been carb icing...but I dont know owt!!Never done it since! Quote
slugworth1987 Posted November 6, 2008 Posted November 6, 2008 agree with bill sounds like a slippy clutch... new thicker oil may fix it or er new clutch plates should best way would be to inspect the clutch and then you can tell lol Quote
Stu Posted November 6, 2008 Posted November 6, 2008 HiI have noticed that over the last couple of days only sometimes when I pull away in first and sometimes also in second and even with a warm engine that the engine is holding back a bit and then all of a sudden a burst of speed. Its annoying when it holds back and then a shock when it suddenly moves. i think that give it away that its not a clutch problem the engine wouldnt hold back if the clutch was slipping the engine would just rev sky high Quote
Bill_on_a_bike Posted November 6, 2008 Posted November 6, 2008 Yeah but if the clutch plates were sticking together it could be unavoidbly almost stalling the engine. Quote
Guest Posted November 6, 2008 Posted November 6, 2008 It may be the carbs require balancing as they are prone to need it on the zzr600's as mentioned it could be cold air into the carbs causing the petrol vapour to freeze and that can cause this issue but you notice this more as you get to a junction and it stalls as you slow down/wait .Unless the throttle grip are really tight to twist initially and then suddenly free i cant see that being to much of an issue.Does it rev crisply in neutral or does it hesitate ? Quote
Stu Posted November 6, 2008 Posted November 6, 2008 Yeah but if the clutch plates were sticking together it could be unavoidbly almost stalling the engine. if the clutch plates where sticking together there would be permanant drive Quote
Guest Posted November 7, 2008 Posted November 7, 2008 Lots of interesting points.When its holding back its not revving more when I increase throttle, feels like going to cut out but then I keep the throttle on and all of a sudden I am half way down the street.In neutral when warm it idles smoothly like it should.Its normally when I have been going along just fine at higher speeds/gears - then come to a slow in traffic/lights and then want to speed up and for the first like 3 seconds its saying 'ooo I dunno I'm scared' then all of a sudden 'ok you git take this...' (me hanging on).It was ok last night and this morning. Ill see how it goes. Quote
Stu Posted November 7, 2008 Posted November 7, 2008 pete247 was right its carb icing you can buy a fuel addative called proFST which will cure it will only do it on cold days Quote
rosszx9r Posted November 7, 2008 Posted November 7, 2008 it is definately fuel related. kawasaki are known for carb icing issues but they fixed that after the almighty mess they made of the GPz900 by doing a recall and adding all sorts of extra plumbing to keep the carbs warm!ZZR's shouldn't be affected. they came along after kawasaki learnt thier lesson!i would recomend you get the carbs stripped and cleaned by a dealer (unless you fancy a go yourself, it's not that hard! honest!)with the age of the bike it will benifit from this regardless of wether it is carb icing or dirt. Quote
rollazuki Posted November 10, 2008 Posted November 10, 2008 Kawasaki carbs are crap, british fuel is crap, winter is cold.......To isolate the issue, ride along until it starts to happen, pull in, kill the motor. Wait 3-4 minutes(while the ice melts) and ride again, If its OK, then gets bad again, you know its carb icing.Silkolene ProFst does work very well, my CCM was running on it(it ices BADLY) but its very expensive, I tried super fuels, and expensive brands, and to be honest, the super unleaded seemed worse than regular supermarket, so I used cheap fuel and ProFst.I meant it tho, Kwak carbs are pants from that era, many bikes suffered from icing problems. Quote
Platty5791 Posted November 10, 2008 Posted November 10, 2008 im probably completely wrong, but with my old 125cc i had the same problem, and it was water that got into my electrics, just a thought =] Quote
slugworth1987 Posted November 11, 2008 Posted November 11, 2008 id take bike back if its underwarrenty aircraft piston engines (carb'd ones) utalise the liquid cooling system to deice the carb just a thought Quote
Guest Posted November 11, 2008 Posted November 11, 2008 My old Ducati Monster used the oil cooler to pipe warm oil around the carbs in the winter, it worked but only once the bike was upto temperature. Quote
chris128 Posted November 16, 2008 Posted November 16, 2008 I know this doesnt help but my car (MG ZS 120) has been doing the EXACT same thing as of about 2 or 3 months ago and its really annoying when you go to pull out and roundabouts/junctions!I've just kind of learnt to live with it as I'm probably going to get rid of the car soon anyway, hope you get yours sorted though. Quote
