handyandy24 Posted November 11, 2008 Posted November 11, 2008 Hey guys. one sodding header bolt is chewed to frig, rusted to frig and is on so f**king tight i cant get it off. all the rest come off with some pain but this one wont budge. its where the downpipes attach at the top so there is little room to get any tools in. wd40 has been used cant get mole grips in. any tips? Quote
Guest Posted November 11, 2008 Posted November 11, 2008 as for knackered bolt is it an actual bolt or a nut ?if you can actually get a good prchase on the head/nut run the bike for a while ( re insert other bolts) and try it with it hot and if possible with a hammer and a pin punch or similar give it a few sharp taps on the head to try and jar its grip free if a nut stry splitting the nut either with a nut splitter or a hacksaw blade slicing the nut in half or if its possible and you have the tools Centre punch two/three marks on the side flat of nut and then find a drill bit that will allow you to drill three ( or even two will do it) and drill the holes allowing you to split the nut that way with limited access its hard to give suggestions some options are ..... weld another nut on the top of the chewed one ( beware of fuel and electrics if doing this ( disconnect fuel tank and battery and unplug cdi unit )cut the head off the chewed bolt ( do it in stages if neccesary ( cut 2/3rds head off and then if you cant get any closer cut chunks off and keep doing so until it frees) and then once the header is off work on getting the remaining stud out with stud extractor etchope these giev you some inspiration but i will add a disclaimer that if you follow any of my ideas it is at your own risk Quote
Stu Posted November 12, 2008 Posted November 12, 2008 as tim says try warming it up use a blow torch if you can to get direct heat on to the stud Quote
slugworth1987 Posted November 14, 2008 Posted November 14, 2008 add alot of w/d40 or plus gas or something along these lines a penertrating oil Quote
handyandy24 Posted November 14, 2008 Author Posted November 14, 2008 Thanks for the tips tim however alot of those suggestions are fairly useless now, while at work my dad went at it with a big ass hammer and chizel so i guess we are limited now as what we can do. Wonder how many hours of chizzeling it will take to disintergrate that nut. :S Quote
Stu Posted November 14, 2008 Posted November 14, 2008 a bolt extractor would do the trick http://www.gomatcotools.com/ProductImages/mbx5.jpg Quote
handyandy24 Posted November 14, 2008 Author Posted November 14, 2008 dont those help take the nut off? or the bolt. the nut has bin half hammered away at the top so anything designed to grip the nut wont work. Quote
handyandy24 Posted November 14, 2008 Author Posted November 14, 2008 i can, wont be till monday tho :S Quote
Guest Posted November 14, 2008 Posted November 14, 2008 Thanks for the tips tim however alot of those suggestions are fairly useless now, while at work my dad went at it with a big ass hammer and chizel so i guess we are limited now as what we can do. Wonder how many hours of chizzeling it will take to disintergrate that nut. :S all i can suggest is a file then lol and try to file it down until you can break the nut in half Quote
fazerdai Posted November 15, 2008 Posted November 15, 2008 as tim says try warming it up use a blow torch if you can to get direct heat on to the stud Put the other nuts back on and start the engine that will warm it up Quote
Guest Posted November 15, 2008 Posted November 15, 2008 as tim says try warming it up use a blow torch if you can to get direct heat on to the stud Put the other nuts back on and start the engine that will warm it up cough cough as for knackered bolt is it an actual bolt or a nut ?if you can actually get a good prchase on the head/nut run the bike for a while ( re insert other bolts) and try it with it hot and if possible with a hammer and a pin punch or similar give it a few sharp taps on the head to try and jar its grip free Quote
slugworth1987 Posted November 15, 2008 Posted November 15, 2008 you need a Colbolt drill bit (about 1/2D to the threds) and some easy outs (cromwell supply all these for a good price) just ont snap the easyout inside the threded shaft or well ull need a few colbolt bits to get past the easy out drill about 5mm into the shaft and then the easy out will grip and twist it free a 1/4 or 3/8 speedy brace with the correct addapters will make the job easier the easy outs are extract turn only molgrips will also work on the easyout tool Quote
handyandy24 Posted November 22, 2008 Author Posted November 22, 2008 updatemy mate cut the bolt in half and the thing wont come out with molegrips. my dad tried taking another bolt out with a stud extractor tool but it came half out then snapped. realllly brittle studs/bolts. will av to look into the mentioned above:S cheers guys Quote
