Guest Posted February 4, 2007 Posted February 4, 2007 was tinkering with the bike seeing as i cant go out on it.. and think i cracked the lil plastic insert on my throtle handle. the grip was rubbing slightly on my bar end... with a lil gentle persuasion, i managed to get it to stop rubbing.. but my gentle persuasion may have been lil heavy handed.. and now.. my throtle has loads of free play.. (back and forth) any ideas on if i tighten my throttle, this will sort it or is it time for a new throttle handle?? Quote
Guest Posted February 4, 2007 Posted February 4, 2007 If it ain't broke don't try and fix it springs to mind Quote
Stu Posted February 4, 2007 Posted February 4, 2007 with the grip rubbing you might not of noticed the free play as much follow the cable and there will be an adjustment screw somewhere adjust untill you are happy with the free play i go for around 2 to 3 mm of play i like mine responsive start the bike and go lock to lock with the bars to make sure the revs dont increase if they do then its too tight hope that helps stu Quote
Guest Posted March 26, 2007 Posted March 26, 2007 i was tinkering with my triumph once,,bit bored,you know how it is!decided to fix a broken front mudguard mount,,,took a drill to the broken bolt,,,went off line and drilled right thro the fork leg!!!!it bled oil profusely and i cried alot!!! the moral is this,,,if you are bored,,,go read a book,,take a walk,,do NOT TINKER!!!!! Quote
Guest Posted March 26, 2007 Posted March 26, 2007 i was tinkering with my triumph once,,bit bored,you know how it is!decided to fix a broken front mudguard mount,,,took a drill to the broken bolt,,,went off line and drilled right thro the fork leg!!!!it bled oil profusely and i cried alot!!! the moral is this,,,if you are bored,,,go read a book,,take a walk,,do NOT TINKER!!!!! http://i153.photobucket.com/albums/s210/edster71/chuckle_brothers_270.jpg Quote
Guest Posted March 26, 2007 Posted March 26, 2007 "TO YOU" Stew......and you can get your hands off mine!!! Quote
