hello all
after an oil change, chain tighten and new front bulb changed i have an issue...
there is a strange vibration on the r/h footpeg at speed above 10mph and low-mid range rpm its not the gearbox i dont think as if i pull the cclutch in it is still there i fear its the chain or wheel i havn't lubed it for a while and the bike was jetwashed yesturday after oil change etc.
ill lube chain aand update but in the meantime if you have any ideas let me know
you have got a ghain link or 2 that have rusted mate hence a knock feeling i bet, get som lube on ya chain before it knotches ya sprockets
you did find the tightest spot on your chain and tension it to that didnt you ?
sounds like a stiff link or tight spot in chain :)
the chains tention isnt tight its got about an inch of play as sugested by the manual like i said i dont think its the gear box because the vibration follows like a wave pattern
did you check the chain tension with your weight on it ?
as it tightens up when you sit on the bike :wink:
also did you check to see if there was a tight spot in the chain ? :?
Chain is to tight :oops: had my nan sit on it this morning and yes stu sorry i didnt realise that someone had to purch the bike as you tighten it... duhhhhhhh :oops: fixed now and all im getting now is feedback from the swing arm and engine like normal yay the squeak from the chain and front cog has also gone with some help of old engine oil will get some chain loob once payday arise's wooo i was worried the gearbox was caputting
why bother getin lube if you have some old engine oil ?
thats all i use is old engine oil :)
