stevie16v Posted November 23, 2008 Posted November 23, 2008 Right, had a wee problem with my bike, its an sr 125 been lying for a year. I have done a full service, stripped and cleaned the carb too. So put it all back together and it starts with a full charge from the battery, however after a few minutes, it starts spluttering and the idle drops until it eventually cuts out. If i rev it, it splutters aswell. I have put the fuel, air idle etc at the correct position. When it does die, and i try to restart it, i get the ancient doorbell sound from the solenoid clicking, Check, the battery and it has dropped. I have checked the charging circuit and its producing a healthy 14v plus, but the battery doesnt seem to be retaining it. So, any suggestions? I'm guessing, new battery. but surely that wouldnt cause the rough running would it? Quote
Stu Posted November 23, 2008 Posted November 23, 2008 once the bike has started it should run fine off the output from the charging system not the battery but it does sound as if your battery is duff anyway so may aswell replace that with it been stood a year have you put fresh fuel in the tank ? Quote
stevie16v Posted November 23, 2008 Author Posted November 23, 2008 Yup sure have. I have replaced the fuel, now got a full fresh tank, cleaned the carb, oil and filter and spark plug aswell Quote
