Guest Posted December 7, 2008 Posted December 7, 2008 Hi - I am trying to find out what size socket/tool I need to undo the front axle nut on my Kawa ZZR (ZX600 E7) thats 1999 model. A bloody large allen key would probably do it and they show a picture in the Haynes manual of someone using an allen key but you cant torque it back up with an allen key eh.I bought a motrax spindle key ('for all modern kawa, suzi and yamaha models') but it doesnt fit - key is too big. I have what looks like a spark plug tool that fits it but dont fancy using that - bodge job.Also do you know if it possible to put the axle in the wrong way as I assumed I would be undoing it from the left hand side but I am thinking it might actually be the right hand side that needs undoing.Anyone know of a reliable and cheap torque wrench covering a good range of torque I can get (20nm to 120nm perhaps)Cheers for any help. Quote
Guest Posted December 7, 2008 Posted December 7, 2008 10 and 12 mm hex iirc will check later for you or is it 12 & 14mm anyway will look in a bit ...useless post i know but i cant be arsed to go out at the moment lol Quote
Guest Posted December 7, 2008 Posted December 7, 2008 and dont forget to undo the two little hex pinch bolts at the baseof the forks that clamp the spindle nut tight ... torquewrench go for a reasonable quality one and dont buy the cheapest as they won't take the use ( and dont use it for undoing nuts )on one side of spindle is just basically a nut other side has the axle through it on mine if looking from front of bike left hand is the axle part and right hand is the nut part so i just undo the left hand pinch bolts and undo the axle/spindleright hand one keeps it tight not needing the other hex but when doing it up i use both Quote
Guest Posted December 7, 2008 Posted December 7, 2008 btw if you have the original tool kit it has a double ended tube spanner that has the correct sizes on it Quote
slugworth1987 Posted December 8, 2008 Posted December 8, 2008 to torq the axel you can get a 1/4 to 8mm socket and stick the torx bit into the 1/4 square drive to get the correct torq.whats a newton meter? lol only ever torqued up into lb/in or lb/ft lolso all you want isa 1/4 drive toque wrenchScrew bit to 1/4 drive socketcorrect size torx bit for the bike Quote
Guest Posted December 8, 2008 Posted December 8, 2008 to torq the axel you can get a 1/4 to 8mm socket and stick the torx bit into the 1/4 square drive to get the correct torq.whats a newton meter? lol only ever torqued up into lb/in or lb/ft lolso all you want isa 1/4 drive toque wrenchScrew bit to 1/4 drive socketcorrect size torx bit for the bike hmmm 1/4 drive is not recommended for torque'ing high torque bolts especially zzr front wheel .... minimum 3/8 drive but 1/2 drive is better Quote
slugworth1987 Posted December 8, 2008 Posted December 8, 2008 sorry when someone says xx nm i dont know how high of torque tht is lol if they said 300 in/lb i would say a 3/8 with 1/4 adapter for screw bit lol Quote
