new tyre advice
right i know this has been asked sooooooooooooo many times but each person has a different need
i need new rear tyre ...
its a metzler mez4 been on bike since middle sept and its down to its limit ( well the edges are still ok but centre /inner edges are low) its done me 8k so im not that bothered ......
question is due to my need for a good hardwearing tyre for the distances i do but i still want a tyre that i can feel confident with as i have with the metz .....
had conti avenue on the old gpz which were hard weraing as i got 15k out of the rear but the grip was shocking so not going down that route...
so in reality i need a dual compound that offers the best of both and at a decent price ... ideas please
I had Pirelli Diablo's on my 916 and they were a great all round tyre. I'll definitely look at them to replace the Dragon Corse's I've got now which really don't do winter! :shock:
I've heard the Dunlop 2CT (i think thats what its called!) is also a great all rounder. But I've never used it myself.
Hope this helps! :cheers:
I belive you better off with the same front and rear , as a front will norn do approx 2 rears you should change both to what ever tyre you want when the front needs changing
with regards to the same front and rear i agree and the front is still good ....only problem is that metzeler stoppeddoing the mez4 :( so i either have to source one from ebay etc and gthen go to local tyre and try getting it fitted .
Or i get a new set front and rear..and yes i am thinking along the lines of bt021 from what i read in other posts ... just that flaming thing of £80 for one tyre if i can find one or £150+ for two new ones ..... ......... grrrrrrrrrrr
Go for two new 'uns m8. Call it a christmas treat or whatever. you could always flog the old front as a part worn...
Michelin Road pilot 2 on mine Tim dual compound. Last a long time and give confidence.
cossie - thought corsa's where a bit soft or is that just the diablo's?
i'm on bt020's. plenty of grip and confidence and good long life on them
