cbr 600 f sport dead battery
is the battery under the front seat?
do you have to take the rear seat off then undo the two bolts to release the front seat or do you just take the side cowl off?
cheers
tony.
You undo the two bolts at the rear of the front seat and then remove the seat by pulling the rear of the seat upwards and back.then your battery is under the cover.
to help in removing the battery there is a hole underneath the battery box so you can push the battery up to get a grip of it.
You dont need to touch the the back seat
