Hi all,
has anyone converted a Suzuki GS500E to 'F' before?
I've spotted the side fairings for sale and i've contacting the seller about the top fairing.
Does anyone know if the bars or anything needs to be modified for the conversion.
Also was thinking about the clocks on the 'E' are double pod type, is there any GS500F owners out there who can tell me what their clocks are like? i.e. integrated into the top fairing or just the double pod type same as mine?
I'm missing the protection i used to get on my CBR 125 (lol) from the wind etc and was heading down the track of getting a fly screen etc etc.. just thought this might be a viable option.
Cheers
Chris
I thought the difference was the fairings
the only difference? i've seen a few aftermarket fairings for 'em which require you to fit a different set of handle bars to allow it to fit.
if its a straight swap i might just get it all and try it.
GS500E has Clip-Ons, whereas the GS500F has Standard Bars. You should be able to convert to bars simply.. Using Risers, or get hold of the top Yoke (Alloy Bit) when getting the fairing.. and brace. The Clocks seem the same.
GS500E
wow thanks for that very useful!
I've attached a comparison between that one / mine....
What do risors look like? i presume they aren't what mine has already (circled in picture)..
One more question.. is the headlight unit for the GS500F interchangable with any other Suzuki's? Gsxr etc? Might make tracking them down a bit easier..
Thanks!
Chris
Thanks!
Chris
Chris, You're in luck you have the same yolk as that fitted to the GS500F, as in that you have standard bars, the risers are the alloy bits the bars clamp into... clip ons, are clamped to the forks, if you look at the bike on the left there isn't a conventional handlebar, thats clip-ons, ..
Clip ons generally give a lower stance, and a more forward racing position, whereas for the fairing you need clearance for lock to lock (turning circle) so the bars are mounted higher to not foul the fairing..
you would be better trying to get a complete unit, that way you get all the bracketry required.. along with headlight etc, but the headlight is reminiscent of a GSXR item, but are they the same? i don't know.
Thanks a lot for your replies Frankie i've had a good look into what i'd need.
At that point I thought damn its going to cost probably half of what the bikes worth to do so i've decided i'll have to let it pass.
you never know i might get a new bike later in the year...
for now i've ordered a little screen instead lol..
I found that the actual fairing wasn't that bad - a couple of sellers on ebay had them for about 40 -50 quid per peice (2 x side, 1 x top)
but then realised i'd need the massive bracket which it connects with (possibly two), new screen, new headlight so i think its a bit too much to do to my 8 yr old bike..
hopefully the thread wont go to waste though as i'm sure someone else will search for it in the future!
cheers
Chris
cheers
Chris
You could always search ebay for a GS500 bikini / cockpit fairing, they are easy to fit look good and come in round the £50-60 mark..
Heres one fitted to a GSX1400
