Guest philgale
if its just stuck on get a hair dryer on it for a bit then just pull it off, the heat will melt the glue
if there is some residue left nail varnish remover works well
Sounds a bit iffy,, would have thought anything that melts & removes nail varnish,, might do the same some paints
Isopropyl alchohol removes residue without damaging the paintwork.
It can be found in hand gel form at pharmacies.
Guest philgale
i used it on mine and it was fine, didnt use loads mind only a little
Again, Hair dryer to soften the adhesive, or a warm sunny day, but youll be waiting.....
and either a wax polish or tar/bug remover to remove the left over adhesive, with lots of elbow grease, whichever method you use, remember to wax the tank after as you will remove any wax on there with spirit or nail polish remover..
just take it slow and don't rush things..
But is it any good with coke or splash of tonic :roll:
Good enough for the alkies in A&E to nick and drink the hand gel!
