T180985 Posted February 22, 2009 Share Posted February 22, 2009 ok i need a garage that can replace the cam chain on my Kawasaki ZXR400 i managed to get hold of one garage who told me it was a nasty little job and he didnt really want to do it, so if any of you know of a decent garage that will do it please can you send me some details? thanks Quote Link to comment Share on other sites More sharing options...
Bill_on_a_bike Posted February 22, 2009 Share Posted February 22, 2009 I'd imagine it will be total pig to do. Don't expect it to be cheap. Quote Link to comment Share on other sites More sharing options...
T180985 Posted February 22, 2009 Author Share Posted February 22, 2009 yea thats what he basically said, bikes still running its just making alot of noise at the moment Quote Link to comment Share on other sites More sharing options...
Bill_on_a_bike Posted February 22, 2009 Share Posted February 22, 2009 Sure it actually needs replacing? Not just tightening? Quote Link to comment Share on other sites More sharing options...
T180985 Posted February 22, 2009 Author Share Posted February 22, 2009 well im hoping thats the case, so ive bought a new cam chain tensioner rod which im hoping will do the trick should be here in a few days Quote Link to comment Share on other sites More sharing options...
Alex Gold Posted February 22, 2009 Share Posted February 22, 2009 If it's anything like the zephyr the tensioner will do f**k all....you can actually check it by taking the tensioner out (with the cam cover off) and extending it to full adjustment, then measuring it, sticking a screwdriver in that distance and seeing if it tightens up. If not, the chain needs changing. Quote Link to comment Share on other sites More sharing options...
Stu Posted February 23, 2009 Share Posted February 23, 2009 the zxr tensioners arent that bad but sometimes the spring can go weak and not adjust up properly the trick is to pull it out and reset it then put it back in and it usually tensions it up properly now then cam chain is a pice of piss to do i did one on my zxr when i had it have you got a manual ? just follow it its as easy as that Quote Link to comment Share on other sites More sharing options...
T180985 Posted February 23, 2009 Author Share Posted February 23, 2009 the zxr tensioners arent that bad but sometimes the spring can go weak and not adjust up properly the trick is to pull it out and reset it then put it back in and it usually tensions it up properly now then cam chain is a pice of p*ss to do i did one on my zxr when i had it have you got a manual ? just follow it its as easy as that Yea I have a manual but couldn't find anything about the can chain will take another look today I think I'm not very good with fixing engines so might be a bit of a challenge for me LOL Quote Link to comment Share on other sites More sharing options...
Stu Posted February 23, 2009 Share Posted February 23, 2009 it depends what manual you have some are crap and have bits missing i think i have one somewhere i will look Quote Link to comment Share on other sites More sharing options...
rollazuki Posted February 23, 2009 Share Posted February 23, 2009 The Zxr workshop manual does say it requires a full engine strip to swap the chain, BUT it can be done without.Remove cam cover, remove tensioner etc and igniter cover.You did set the timing at tdc first didnt you??Make note of the cam markings to ensure they are refitted in the correct timed position, and count links between the markings.Remove the chain(you will usually have to remove cams as the new chain will be tighter)drop the camchain down the tunnel, and then using EXTREME patience, sneak it past the sprocket on the crank, trying to avoid breaking off the small ally tang that is there to prevent you from removing it in situe.You can do it, and cause no damage to the engine.Rebuild and check timing, turn engine over by spanner first to check for any clearance issues.Id always replace the chain and slipped blades and tensioner. They all wear.Zxr4's were always a little camchain rattly tho, so ensure it needs doing before pulling it apart.Rolla Quote Link to comment Share on other sites More sharing options...
