When to change brake fluid
XmisterIS
My brake fluid is getting pretty yellow (presumably because it's old). When should I change it? The bike has 12500 on the clock, I don't know if it's had a brake fluid change. The brakes work fine though.
Ah! A good ol' case of RTFM ... :o
Why should it need changing anyway? Presumably, it's just a sealed hydraulic system, with some liquid in it, why does the liquid ever need changing at all? I'm just curious to know!
the system resivour isnt a sealed unit it breaths much like a fuel tank or any system with liquid. with air comes moistour
as the fluid absorbs water it looses it boiling point as stu said dot 4 will last upto 2 years in ideal conditions but should be changed when it starts to yellow once its brown/coffee colour it should defentaly be changed. same as clutch system if its dot 4.
to save money people have converted to DOT5.1 which lasts longer under water, has a better more efficant boiling area. DOT 5.1 isnt silicon based like DOT5 so is safe to super seed DOT3/4 systems
You're supposed to change it every two years as it absorbs moisture and other contaminants from the braking system reducing the effectiveness and boiling point of the fluid. TBH if your brakes are working fne and you're not experiencing any brake fade, excessive lever travel or spongyness don't worry about it too much. However fluid is relatively cheap as you don't require much and it's easy to change too so it wouldn't hurt if you really wanted to change it.
My brake fluid reservior on my handlebars says "DOT 4" ... can I just chuck DOT 5.1 straight into it?
this is wrong
5.1 absorbs water and needs changing more often
have a read here :wink:
http://au.geocities.com/ozbrick850/brak ... types.html
