Guest Posted March 14, 2009 Posted March 14, 2009 Hi folks.My wifes Suzuki 800 Marauder will start with the choke but once I twist the throttle it dies.I have let it warm up but no joy.Any suggestions would be appreciated.Thanks Quote
Guest Posted March 15, 2009 Posted March 15, 2009 Problem with your fuel getting to the chamber? Is it DI or carb?I had the same problem in the winter due to carb freezing... Quote
Revvin Kevin Posted March 15, 2009 Posted March 15, 2009 Yep does sound like fuel delivery problems. Quote
Guest Posted March 15, 2009 Posted March 15, 2009 Thanks for the replies folks will have to check it out next weekend.Cheers Quote
Guest Posted March 15, 2009 Posted March 15, 2009 recent history and background information may help diagnosishas it been sat not used for period of time it is in neutral it does it do it only in gear going to pull off petrol in tank ... if so how old is it ( and if recently filled up how old was the fuel in the tank previous) Quote
Guest Posted June 21, 2009 Posted June 21, 2009 had this saturday on my GSX, turns out I had disconnected the vacuum hose under the tank, so there was no overpressure on the fuel to send it down the pipe.. Quote
